world block problem #304187
04/30/09 10:42 PM
04/30/09 10:42 PM
KY
juicedcuda Offline OP
KY
A buddy of mine is building a stroker using a new iron world block. The motor is almost finished but the shop is running into a problem. It seems the cam gear is hitting the timing chain cover. He tried several different covers with all the same results. They tried double gaskets and still no luck. Everything is lined up internally as well. Anyone else ever hear of this happening?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: world block problem [Re: juicedcuda] #304188
04/30/09 11:01 PM
04/30/09 11:01 PM
gregsdart Offline
gregsdart  Offline
Is the cam walking forward? I had a big problem with that. Had so much forward thrust I wound up with a geardrive, and a pressure oiled thrust button.
Re: world block problem [Re: juicedcuda] #304189
04/30/09 11:24 PM
04/30/09 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing I can think of is the surface that
the timing cover bolts to was machined down too far,
since you tried multiple covers and they all did the
same. I assume all the lifters line up on the cam
properly and the timing gear isnt forward
Re: world block problem [Re: MR_P_BODY] #304190
04/30/09 11:40 PM
04/30/09 11:40 PM
KY
KY
Everything is lined up on the cam. And the timing gear seems to be in the correct place. I was wondering about the surface being machined to low as well.
Re: world block problem [Re: gregsdart] #304191
04/30/09 11:41 PM
04/30/09 11:41 PM
KY
KY
If everything is lined up, could it still be too much forward thrust. How does he check this?
Re: world block problem [Re: juicedcuda] #304192
05/01/09 03:07 PM
05/01/09 03:07 PM
NC
440Jim Offline
440Jim  Offline
NC
I would try another timing set, then you should be able to tell if the block is machined wrong or the timing gear is sticking out too far. Is it hitting the cam bolts or the chain?
Re: world block problem [Re: juicedcuda] #304193
05/01/09 04:39 PM
05/01/09 04:39 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Check the obvious first. I had an issue once when I didn't "seat" the crankshaft gear all the way back. The crankshaft gear was very tight on the crank. Because of that, the chain pulled the cam forward just enough to touch. I also had to grind a little off the cam gear bolt heads.
