Re: Todd Hoven AA/SA '65 Dodge Coronet 426ci HEMI
[Re: bigdad]
#3040998
05/09/22 04:12 PM
05/09/22 04:12 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Didn't you post the same video a few weeks back?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: bigdad]
#3041011
05/09/22 04:56 PM
05/09/22 04:56 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
Yes and Todd suffered some injuries as a result of the hard landing from the wheelstand, the car also suffered some damage
[Re: jwb123]
#3041146
05/10/22 09:03 AM
05/10/22 09:03 AM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
I I wonder why his wheelie bars were set so high, they basically did nothing to control the wheel stand. The bane of leaf spring cars.
[Re: jwb123]
#3041162
05/10/22 10:31 AM
05/10/22 10:31 AM
Posts: 31,052 Oregon
AndyF
I I wonder why his wheelie bars were set so high, they basically did nothing to control the wheel stand. Forgot to reset them after unloading from the trailer or else they wanted them out of the way so they could do a wheel stand. Or maybe they thought the wheelie bars were unloading the car so the moved them up for test run. Hard to know without actually being there.
[Re: jwb123]
#3041174
05/10/22 11:31 AM
05/10/22 11:31 AM
Posts: 2,931 A shed in England
Tig
A shed in England
I I wonder why his wheelie bars were set so high, they basically did nothing to control the wheel stand. Caltrac car ? We are the same. You need to set them high If they are std, comp engineering type axle mounted ones, they just work against the Caltrac bars and unload the tyres. The Calvert wheelie bar is designed to work with Caltracs and works well, but you need to remove the stock tank and reinforce the striker area. You can just make out the wheel on the bars at the back on ours.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: HardcoreB]
#3041229
05/10/22 02:30 PM
05/10/22 02:30 PM
Posts: 34,934 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
FWIW ..
I searched and could not find where I posted it previously .. I am a bit senile so, it still is possible
( you have to double, triple check every post here to just try to not get called out on some small error )
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3041233
05/10/22 02:42 PM
05/10/22 02:42 PM
Brad_Haak
Loudoun County, VA
Yes, it was posted previously. No, it wasn't posted by bagdad. HERE!
