Page 3 of 4 1 2 3 4
Re: Lets talk Heads..... [Re: rb446] #3036363
04/23/22 03:32 PM
04/23/22 03:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by rb446
ok John, no worries what you do is cool man.
You to buddy. Some people compare dyno sheets and some guys RACE.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lets talk Heads..... [Re: pittsburghracer] #3036440
04/23/22 07:56 PM
04/23/22 07:56 PM
gregsdart Offline
gregsdart  Offline
Originally Posted by pittsburghracer
You dyno and horsepower guys kill me. Lol. Get the damn thing to the race track and put in some work. My little 422 with a solid lifter cam has gone a best of 5.98 and a boat-load of low 6.00’s. Not at some coastal super track either. Off the shelf pistons, no vacuum pump, no special ring packs, and a bracket sized tire 4 inches bigger than needed. Sure it’s 2880 pounds but yours could be too.
John, i think you missed a point. To meet both goals, pumpgas and season long reliability in a bigblock, it can be done, but will push stock blocks hard to achieve it. I want to hear Dragula won a season championship in shat air, run 5.900 in doing so and only had to change oil and check lash for the next season. That takes a pretty conservative, large motor to do. So that is my thoughts on how to get there based on experiance. The low stress is key, and allows money to be spent on a good base, like an aluminum block. With a combo like that, a data base for racing can get real long and accurate, unlike my last fifteen years of chasing ets.
Re: Lets talk Heads..... [Re: Dragula] #3036523
04/24/22 08:57 AM
04/24/22 08:57 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted by Dragula
TF270 vs. Indy 325 Big EZ1.....on a 512/400 ......B1's are not being considered due to special pistons required.
What's your thoughts? Which will make more HP? About to pull the trigger here.
The only base info with regard to a TF270 going 5.90's was HP given from a dyno. I wouldn't trust (spend money) based on that. Unless you are trying to be the first at something. That 470 Could have run 6.20's then what? You'd be stuck (spending more money).
Has anyone gone 5.90's with the 325EZ? Again just curious.
Re: Lets talk Heads..... [Re: B1MAXX] #3036565
04/24/22 12:20 PM
04/24/22 12:20 PM
AndyF Offline
AndyF  Offline
This car has EZ heads on it. Last year he ran a stock block 505 with TF270 heads on it. The 505 made about 750 hp with the TF270 heads, makes even more with the EZ heads although now he has a 572 inch shortblock under the EZ heads.
Re: Lets talk Heads..... [Re: AndyF] #3036574
04/24/22 12:32 PM
04/24/22 12:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The TF270 vs EZ295 vs EZ325, on a 800hp type 540+ short block would be a fun dyno shoot out.
Then finish it off with some 440-1 cnc345’s.
Re: Lets talk Heads..... [Re: fast68plymouth] #3036590
04/24/22 01:13 PM
04/24/22 01:13 PM
AndyF Offline
AndyF  Offline
It would be a very good dyno shootout. Just need $30,000 and a year or so to round up the parts!
I'm pretty sure I know how things would stack up but there is typically a surprise in the pile. Big question would be the cam. You can stack the deck either way by optimizing the cam for one end or the other. Probably get the best reaction from the crowd by using a big cam that was designed for the -1 heads. Then you get a big bang at the end of the shootout.
540 with 13.5 compression and a ported intake with a 1250 carb should make 750+ with the 270 heads and end up around 850 with the -1 heads.
Re: Lets talk Heads..... [Re: AndyF] #3036640
04/24/22 04:44 PM
04/24/22 04:44 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What did it et with the 505?
Re: Lets talk Heads..... [Re: B1MAXX] #3036672
04/24/22 06:18 PM
04/24/22 06:18 PM
AndyF Offline
AndyF  Offline
9.70 to 9.90 depending on conditions
Re: Lets talk Heads..... [Re: AndyF] #3036688
04/24/22 07:30 PM
04/24/22 07:30 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
Let's not forget my friends car that I sponsored and wrenched on for years. It has gone 5.87 at about 117mph with a set of eddy rpm's that are pretty much maxed out. Hughes flat tappet cam, tunnel ram 2 750 holleys. About 2850#. 499RB. If I knew how to post a pic, I would.
Re: Lets talk Heads..... [Re: fast68plymouth] #3036702
04/24/22 08:30 PM
04/24/22 08:30 PM
A727Tflite Online content
A727Tflite  Online Content
Where do a set of maxed out B-1 heads fit in this line up?
Re: Lets talk Heads..... [Re: A727Tflite] #3036704
04/24/22 08:35 PM
04/24/22 08:35 PM
AndyF Offline
AndyF  Offline
North of the 440-1 heads
Re: Lets talk Heads..... [Re: AndyF] #3037707
04/27/22 07:16 PM
04/27/22 07:16 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
This is Andy F's old 514 with Indy EZ heads and a hand ported Victor Intake it went a best of 9.64 @ 138, 1.33 60' @ 3800 lbs with me 210lbs on a 9" slick
Re: Lets talk Heads..... [Re: 10secGTX] #3037782
04/27/22 09:40 PM
04/27/22 09:40 PM
AndyF Offline
AndyF  Offline
Nice picture. You have that car hooking up and going! Nice level wheelie too. Doesn't get much better than that.
Re: Lets talk Heads..... [Re: A727Tflite] #3037915
04/28/22 10:27 AM
04/28/22 10:27 AM
So. Burlington, Vt.
So. Burlington, Vt.
Imo, “Maxed out” B-1’s wouldn’t even be part of the conversation unless one was shooting for, and building something capable of over 900hp.
Re: Lets talk Heads..... [Re: 10secGTX] #3037921
04/28/22 10:55 AM
04/28/22 10:55 AM
AndyF Offline
AndyF  Offline
Super Victor intake with a Dominator, or Victor?
Re: Lets talk Heads..... [Re: 10secGTX] #3037979
04/28/22 01:58 PM
04/28/22 01:58 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
This engine makes good power for Indy EZ heads. I'm sure there's more in it based on the mph/weight/ET not lining up. Probably a solid 850HP. Nice car/combo!
Re: Lets talk Heads..... [Re: HardcoreB] #3037981
04/28/22 02:03 PM
04/28/22 02:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looks good!!
Re: Lets talk Heads..... [Re: HardcoreB] #3037987
04/28/22 02:26 PM
04/28/22 02:26 PM
AndyF Offline
AndyF  Offline
Looks that way. That 514 usually made between 850 and 900 hp on the dyno when we were using it for part testing but in those days it had a dry sump system as well as a Wilson ported intake so it isn't the same combo that we ran: https://www.motortrend.com/how-to/modify-carburetor-run-oxygenated-race-gas/
Re: Lets talk Heads..... [Re: 10secGTX] #3038086
04/28/22 11:46 PM
04/28/22 11:46 PM
AndyF Offline
AndyF  Offline
Do you have a rear anti-roll bar in that car? The lift looks very square with the front of the car nice and flat rather than torqued over.
Re: Lets talk Heads..... [Re: AndyF] #3040100
05/05/22 09:14 PM
05/05/22 09:14 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Sorry for Late response.... No anti roll bar ... Looking into it, I have 4.30 gears and crossing the stripe at 7500 + so I may change back to my 3.90 gears also got some Menscer Rear shocks.
I'm more worried about Diesel prices than race gas
Page 3 of 4 1 2 3 4
