Ring gear opinions #3039883
05/05/22 08:37 AM
05/05/22 08:37 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Was going to sell a 3.54 Dana I had left over and not re-used.
Was going to pack for a buyer and under closer inspection I noticed
two gears had fissures that at first I thought were damage from the previous use.
After looking more closely, it seems to me they look more like casting flaws.
What are your takes on this ring gear, scrap or maybe usable for moderate street use??
Thanks,
Joe
PS., no other signs of any debris marks or damage anywhere else.
Re: Ring gear opinions [Re: jlatessa] #3039906
05/05/22 10:18 AM
05/05/22 10:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If I were a buyer, I would not accept those nor would I use them in my own car frown pity
Re: Ring gear opinions [Re: TJP] #3039913
05/05/22 10:37 AM
05/05/22 10:37 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You have a nice boat anchor there and I would never put that in a car either.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Ring gear opinions [Re: jlatessa] #3039915
05/05/22 10:42 AM
05/05/22 10:42 AM
N
NITROUSN Offline
NITROUSN  Offline
N
They got hurt. Time bomb now. Junk.
Re: Ring gear opinions [Re: NITROUSN] #3039922
05/05/22 10:57 AM
05/05/22 10:57 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
So then the mating pinion is part of the anchor too?
Thanks guys, all answers I expected....
Joe
Re: Ring gear opinions [Re: jlatessa] #3039926
05/05/22 11:07 AM
05/05/22 11:07 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Cracked - junk. Dings, not in the contact area - die grind the sharp edges smooth and use. Would not sell to someone. Use it, give it away to someone willing to use it or scrap.
Picture is hard to see. Looks like a crack on the one tooth which would disqualify it from being trusted.
Used gear that is not rare may not be worth fooling with. Something expensive or not easily replaced, I would fix it if I needed to use it, depending on the crack..
Re: Ring gear opinions [Re: CMcAllister] #3039931
05/05/22 11:14 AM
05/05/22 11:14 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I won't sell something that I wouldn't trust myself. I'd make a clock out of that.
Re: Ring gear opinions [Re: jlatessa] #3039936
05/05/22 11:25 AM
05/05/22 11:25 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Joe
Yes, they are a matched set.
Re: Ring gear opinions [Re: jlatessa] #3039994
05/05/22 02:57 PM
05/05/22 02:57 PM
Ring and pinion gears, as well as all other automotive tranny and rear end gears that I know of are not cast or poured into a mold, they are drop forged is what I have been told by several major vendors of them scope
As far as that pinion gear teeth,that is not a casting flaw tsk It is, are, hurt from abuse, don't use or sell it twocents
Re: Ring gear opinions [Re: Cab_Burge] #3040093
05/05/22 08:50 PM
05/05/22 08:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
JB and some carefully applied flat black. Then sell them to someone you don't like, might even fog the R&P and claim NOS
LOL whistling beer
Re: Ring gear opinions [Re: TJP] #3040187
05/06/22 06:49 AM
05/06/22 06:49 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
That's how it starts.
