Ring gear opinions
#3039883
05/05/22 08:37 AM
05/05/22 08:37 AM
Posts: 1,318 Ohio
jlatessa
Ohio
Was going to sell a 3.54 Dana I had left over and not re-used.
Was going to pack for a buyer and under closer inspection I noticed two gears had fissures that at first I thought were damage from the previous use.
After looking more closely, it seems to me they look more like casting flaws.
What are your takes on this ring gear, scrap or maybe usable for moderate street use??
Thanks,
Joe
PS., no other signs of any debris marks or damage anywhere else.
Re: Ring gear opinions
[Re: TJP]
#3039913
05/05/22 10:37 AM
05/05/22 10:37 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
You have a nice boat anchor there and I would never put that in a car either.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: jlatessa]
#3039926
05/05/22 11:07 AM
05/05/22 11:07 AM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Cracked - junk. Dings, not in the contact area - die grind the sharp edges smooth and use. Would not sell to someone. Use it, give it away to someone willing to use it or scrap.
Picture is hard to see. Looks like a crack on the one tooth which would disqualify it from being trusted.
Used gear that is not rare may not be worth fooling with. Something expensive or not easily replaced, I would fix it if I needed to use it, depending on the crack..
[Re: jlatessa]
#3039936
05/05/22 11:25 AM
05/05/22 11:25 AM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
So then the mating pinion is part of the anchor too?
Thanks guys, all answers I expected....
Joe Yes, they are a matched set.
[Re: jlatessa]
#3039994
05/05/22 02:57 PM
05/05/22 02:57 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Ring and pinion gears, as well as all other automotive tranny and rear end gears that I know of are not cast or poured into a mold, they are drop forged is what I have been told by several major vendors of them As far as that pinion gear teeth,that is not a casting flaw It is, are, hurt from abuse, don't use or sell it
[Re: TJP]
#3040187
05/06/22 06:49 AM
05/06/22 06:49 AM
Posts: 2,924 A shed in England
Tig
A shed in England
That's how it starts.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
