weights on torque converter- update ?? #303867
04/30/09 03:58 PM
04/30/09 03:58 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
If you change a 318 to a 360 but keep the 318 trans do you have to add weights to the converter to change the balance of the converter? I thought it just bolted up and go, but sounds like its off balance or maybe flywheel is cracked. thanks!!
Re: weights on torque converter [Re: beesting] #303868
04/30/09 04:05 PM
04/30/09 04:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes the converter from a 318 must have weights welded to it to work on a 360 or a B&M flex plate for a 360. 360's are external balanced, 318 internal balanced.
Re: weights on torque converter [Re: MoparforLife] #303869
04/30/09 06:32 PM
04/30/09 06:32 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Not a big thing to do 20$, instructions are in the box..very easy
Daniel
Re: weights on torque converter [Re: Wedgeman] #303870
04/30/09 06:49 PM
04/30/09 06:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
answer is symply like counterweights with cast cranks, and non counterweight with forged cranks... no matter engine.
Re: weights on torque converter [Re: NachoRT74] #303871
04/30/09 07:12 PM
04/30/09 07:12 PM
Upper Midwest
Upper Midwest
Not quite true. 318 cast or forged are internal balance with no additional weights.
Re: weights on torque converter [Re: MoparforLife] #303872
04/30/09 07:46 PM
04/30/09 07:46 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
Thanks for the replys
Re: weights on torque converter [Re: Wedgeman] #303873
04/30/09 10:17 PM
04/30/09 10:17 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Daniel
Just did mine last week......a snap!
Re: weights on torque converter - one more ? [Re: Wedgeman] #303874
05/01/09 11:38 PM
05/01/09 11:38 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
where did you get the kit at, ok 1 more - you do have to drop tranny to do it? thanks again!!
Re: weights on torque converter - one more ? [Re: beesting] #303875
05/02/09 02:59 AM
05/02/09 02:59 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Mopar performance...P4120241 for non magnum 360
Yes you need to taqke the tranny out...
Daniel
Re: weights on torque converter - one more ? [Re: Wedgeman] #303876
05/02/09 06:09 AM
05/02/09 06:09 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
thanks
Re: weights on torque converter - one more ? [Re: Wedgeman] #303877
05/02/09 12:09 PM
05/02/09 12:09 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
Daniel
No you don't I'm a converter builder and saved lots of guys by doing it in the vehicle. All you have to do is figure out where the weight goes and weld it on IN the car.
Id the converter has a drain plug it is real easy to figure out
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: weights on torque converter - one more ? [Re: SANDYinNS Canada] #303878
05/02/09 05:06 PM
05/02/09 05:06 PM
W
Wedgeman Offline
Wedgeman  Offline
W
You are right, you can figure out where the offset bolt is by removing the shield and measuring as you turn the engine......then weld it where it goes.....
Mine did not have a drain plug.....
Daniel
Re: weights on torque converter - one more ? [Re: SANDYinNS Canada] #303879
05/02/09 05:23 PM
05/02/09 05:23 PM
Upper Midwest
Upper Midwest
Daniel
It isn't that bad to do when the converter is in the car. Simple if the converter has a drain plug.
Re: weights on torque converter - update ? [Re: MoparforLife] #303880
05/17/09 08:01 PM
05/17/09 08:01 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
ok my trans is a 904 and my brother had a flex plate from summit well i drop my tranny and take torque converter off here flex plate was finger loose all of the bolts i took off by hand ok my torque has thin weights on the outside of it the part that goes into the tranny not where it bolts to the flex plate . flex plate brother had was on a 727 here's ? would my old flex plate work with no noise if tighten right this time, since there is weights on converter or do i still need special flexplate and if do will brothers work? sorry so long THANKS
Re: weights on torque converter - update ? [Re: beesting] #303881
05/17/09 08:10 PM
05/17/09 08:10 PM
p.a.
420duster Offline
420duster  Offline
p.a.
Not to jump in but ,,,So can you use just a new flexplate ? Or torque converter weights too ? Thanks
Re: weights on torque converter - update ? [Re: 420duster] #303882
05/17/09 08:38 PM
05/17/09 08:38 PM
Upper Midwest
Upper Midwest
The thin weights on the transmission side are to finish balance (neutally) the converter. The external balance converters have larger wieghts on the engine side. Usually in the area of the drain (when so equiped).
