Has anyone ever set up their own starting line/launching pad #3035985
04/22/22 12:03 PM
04/22/22 12:03 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
What if you had your own little chunk of drag strip at home, maybe 150 ft or so and then some shutdown area? You could really get the chassis dialed in. Has anyone done this? If so, how did you build it, how did you prep it?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Has anyone ever set up their own starting line/launching pad [Re: Hemi_Joel] #3036053
04/22/22 02:20 PM
04/22/22 02:20 PM
IL
furious70 Offline
furious70  Offline
IL
you mean not the county pavement in front of the house? drive
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Has anyone ever set up their own starting line/launching pad [Re: furious70] #3036063
04/22/22 03:09 PM
04/22/22 03:09 PM
Minnesota
Minnesota
That would work for the no prep guys! I'm thinking something that could be prepped like a typical drag strip starting line. That a guy could do unlimited launches to test every possible combination to see what the effect is on the 60 ft.
My driveway's a half mile long and it's gravel. I could potentially pave a stretch of it for this purpose. The site is secluded enough that I don't think I would be bothering anybody.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Has anyone ever set up their own starting line/launching pad [Re: Hemi_Joel] #3036068
04/22/22 03:49 PM
04/22/22 03:49 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
always thought about doing my gravel driveway (21 telephone poles long) was going to do first 60 ft concrete, then maybe 100 or so feet asphalt, but know my ex-wife lives there
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Has anyone ever set up their own starting line/launching pad [Re: 440lebaron] #3036101
04/22/22 07:09 PM
04/22/22 07:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For 20 years or so I've wanted a water box and maybe 150 feet, just for 60-foots.
Bet you could charge admission, say $10 a burnout laugh2
Re: Has anyone ever set up their own starting line/launching pad [Re: topside] #3036117
04/22/22 08:14 PM
04/22/22 08:14 PM
IL
furious70 Offline
furious70  Offline
IL
hot tires off the end into the gravel would be a mess of picked up rocks though? It's always been bad for me coming off the highway onto the drive after tomfoolery at least and that's at the end of 1/8mi or so
It would be very helpful to have though!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Has anyone ever set up their own starting line/launching pad [Re: furious70] #3036120
04/22/22 08:22 PM
04/22/22 08:22 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Sounds like an accident waiting to happen. realcrazy
69 GTX 68 Road Runner
Re: Has anyone ever set up their own starting line/launching pad [Re: JERICOGTX] #3036129
04/22/22 08:43 PM
04/22/22 08:43 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
through out the years ive seen pics of private test area,if you have the land.money and all you do is race why not
Re: Has anyone ever set up their own starting line/launching pad [Re: dart games] #3036185
04/23/22 12:28 AM
04/23/22 12:28 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I test in my driveway before we head out to an event. Maybe 150-160 ft of asphalt. You definitely pick up some stones but that happens everywhere with m5 or whatever flavor of sticky tire you run.
The main problem with these driveway antics are trees, buildings and power poles.
If your road is clear of hazards I say go for it. In fact, make at least 660' of it 14ft wide.
If you build it, they will come. Would you have a tree and some sort of timing system?
Re: Has anyone ever set up their own starting line/launching pad [Re: Jeremiah] #3036220
04/23/22 09:07 AM
04/23/22 09:07 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I had one. Concrete with a broom finish. Was great for testing.
Re: Has anyone ever set up their own starting line/launching pad [Re: FastmOp] #3037651
04/27/22 03:59 PM
04/27/22 03:59 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
So I live out of town on 8 acres.
The first 150 feet of my driveway is blacktop.
This is where I do my tire tests and transmission and trans brake tests.
Then I have another 400 feet of almost straight cement.
This is good for testing shift points and braking.
MJ
Re: Has anyone ever set up their own starting line/launching pad [Re: topside] #3037682
04/27/22 05:36 PM
04/27/22 05:36 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Would be fun to have. Without a timing system though, hard to tell by seat of the pants even a few hundreds regards 60 foot
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Has anyone ever set up their own starting line/launching pad [Re: B3422W5] #3037686
04/27/22 06:11 PM
04/27/22 06:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those "Dragy" GPS based systems do some pretty amazing things so I am sure you could use one of those. I have seen lots of people post real time slips next to a dragy app view and they are pretty damn close.
https://dragymotorsports.com/products/dragy-gps-performance-box
68 Barracuda Formula S 340
Re: Has anyone ever set up their own starting line/launching pad [Re: B3422W5] #3037687
04/27/22 06:13 PM
04/27/22 06:13 PM
Minnesota
Minnesota
Good stuff, thanks for the replys. I'd need a timing system to test the effect of changes. My driveway has trees and drop offs on both sides. So I'd need so concrete barriers, or else build it out in the field where there are no hazards.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Has anyone ever set up their own starting line/launching pad [Re: Bad340fish] #3037697
04/27/22 06:55 PM
04/27/22 06:55 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Cool. Looks neat!
1.41 best 60 foot
6.56 at 104.17
Re: Has anyone ever set up their own starting line/launching pad [Re: B3422W5] #3037716
04/27/22 07:37 PM
04/27/22 07:37 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
You could just go to the local 1/8 track that is 45 minutes from your house…
Re: Has anyone ever set up their own starting line/launching pad [Re: Hemi_Joel] #3037746
04/27/22 08:48 PM
04/27/22 08:48 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
We have all dreamed about this .
Re: Has anyone ever set up their own starting line/launching pad [Re: JERICOGTX] #3037798
04/27/22 10:26 PM
04/27/22 10:26 PM
Minnesota
Minnesota
the opportunities are so few.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Has anyone ever set up their own starting line/launching pad [Re: Hemi_Joel] #3037875
04/28/22 08:21 AM
04/28/22 08:21 AM
an8sec70cuda Offline
My driveway is about 1/4 mile long and mostly straight. Hay fields on both sides. Only the portion close to the house is paved w/ asphalt, the rest is recycled asphalt...so it isn't nearly as hard/durable.. Always wanted to do a 100' stretch of it in concrete and then pave the rest of it, but $$$$.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Has anyone ever set up their own starting line/launching pad [Re: an8sec70cuda] #3037923
04/28/22 10:57 AM
04/28/22 10:57 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I live on a "dog bone" where each end of the street is a cul de sac and the neighborhood has cookouts and get-togethers on our end of the dog bone on occasion. My wife and I were going out for dinner the other night when there were a bunch of people hanging out; one of the local Dad's yelled "Do a burnout!" The old expression "Be careful what you wish for..." came to mind, but I slooooowly pulled out of the driveway and drove carefully through the crowd of kids and adults.
These are the same people who think of the 1320 as "the loud car", when the fact is most didn't even live here when the '73 Chally was last running. They have no idea... wink
If I turned our cul de sac into a 60-ft practice pad, people would totally freak. drive
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
