Center Force Clutch and flywheel for A833 4 speed. #3035889
04/22/22 04:33 AM
04/22/22 04:33 AM
usa
bdgtfb Offline OP
bdgtfb  Offline OP
usa
Hi All
I have a 1969 A12 matching numbers, A833 4 speed Road Runner. I am wanting to install a Center Force Dual Friction clutch assembly and flywheel on it using the standard cast iron bellhousing that came on it from the factory. Is a 10.95” disc correct as well as a 130 tooth billet steel flywheel?
I am not that well versed in this area and any help would be greatly appreciated. Thank you
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: bdgtfb] #3035909
04/22/22 08:33 AM
04/22/22 08:33 AM
VA
dragon slayer Offline
VA
What is your bell housing number? That dictates Flywheel. Not 100% sure on A12, but I thought your car would have the cast iron bell housing for the 143 Flywheel for external balance. So you use the standard 11" clutch. In 1970 mopar went to the aluminum bellhouse for the 130 tooth with 11" scalloped clutch (10.95" disc). Either will work, but the bellhouse size determines the flywheel and clutch.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: bdgtfb] #3036000
04/22/22 12:33 PM
04/22/22 12:33 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Just get a flywheel turning tool and a piece of chalk to mark where you left off so you don't lose your place, drop the inspection cover and count the # of teeth on your current flywheel.
Link to a flywheel tool in case you aren't familiar https://www.amazon.com/Performance-Tool-W80510-Flywheel-Turner/dp/B000FW4N5G
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: dragon slayer] #3036036
04/22/22 01:39 PM
04/22/22 01:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Absolutely correct. up BTW, the '69-1/2 A12's are all internally balanced.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: dragon slayer] #3036091
04/22/22 06:26 PM
04/22/22 06:26 PM
usa
bdgtfb Offline OP
bdgtfb  Offline OP
usa
thanks for the help so far. the bellhousing part number is 28922626 39028 - cast iron.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: bdgtfb] #3036125
04/22/22 08:37 PM
04/22/22 08:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Hmm. Govier's book shows a separate number for '68 and '69 for the 11" BB cast iron bell. 2892262 for '68 and 2892626 for '69. I'm not going to stake my life on it but I'm sure they interchange.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: 6PakBee] #3036159
04/22/22 09:53 PM
04/22/22 09:53 PM
VA
VA
They are, the 69 had the bolt pattern for a 4 speed or 3 speed trans I believe. But both are 143 tooth with larger bearing retainer diameter. Got you on the balance, they had normal but hand picked 440 rod right? 70 got the heavy rod external balance.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: 6PakBee] #3036160
04/22/22 09:54 PM
04/22/22 09:54 PM
usa
bdgtfb Offline OP
bdgtfb  Offline OP
usa
sorry, my bad. 2892626 is what i should have listed!
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: bdgtfb] #3045804
05/28/22 09:41 AM
05/28/22 09:41 AM
Chicago
PurpleBeeper Offline
Chicago
So.... you need an "11 inch" clutch and pressure plate. Remove the big spring behind the clutch pedal. I've had good experiences with that centerforce clutch
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: PurpleBeeper] #3045900
05/28/22 02:09 PM
05/28/22 02:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I would NEVER put a diaphram clutch in a Mopar, just MY personal preference, they were never designed for them... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: Rhinodart] #3046053
05/29/22 05:34 AM
05/29/22 05:34 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I agree. I had a lady customer who wanted a soft pedal. The release rate on a diaphragm is all wrong for a Mopar. I called McLoed about it and said that’s correct. It was softer, just hard to release slow. I have a customer
with a Centerforce and it was better. Two more friends had diaphragm styles and just switched back to a borg and beck. They did not like them because of the fast release.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: fastmark] #3046076
05/29/22 09:02 AM
05/29/22 09:02 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Call Mike at RAM for a b&b style clutch setup.
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: Jeremiah] #3046187
05/29/22 03:07 PM
05/29/22 03:07 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have always used B&B plates or the BB&Long Mk12 adjustable that I use when I raced my car every weekend. I got a deal on a Centerforce II plate a few years ago and I said why not try it. I bought a Mcleod 500 series dual friction disc and with the CF plate this has been the absolute best street clutch I have ever used. But I am not one of those "Mopar or no car" purist snobs. Hell I even had a Ford 9" under my car for a while in my racing days.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Center Force Clutch and flywheel for A833 4 speed. [Re: fourgearsavoy] #3046232
05/29/22 07:00 PM
05/29/22 07:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've run Center Force clutches since they came out and just love them. Have one in my 73 W200 and my 72 Dart. Had them in several other cars too. Have to remove the over cam spring from the pedal assy. For me the only better clutch is the McLeod twin disc that I use behind higher HP motors.
My W200 with the popup camper, 64 gal of fuel, John boat and loaded up with gear and people weights in at around 8500#. Climbing over rocks and four wheeling I've abused the crap out of it and it has never failed.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
