Re: Center Force Clutch and flywheel for A833 4 speed.
[Re: dragon slayer]
#3036036
04/22/22 01:39 PM
04/22/22 01:39 PM
Posts: 10,723 North Dakota
6PakBee
North Dakota
What is your bell housing number? That dictates Flywheel. Not 100% sure on A12, but I thought your car would have the cast iron bell housing for the 143 Flywheel for external balance. So you use the standard 11" clutch. In 1970 mopar went to the aluminum bellhouse for the 130 tooth with 11" scalloped clutch (10.95" disc). Either will work, but the bellhouse size determines the flywheel and clutch. Absolutely correct. BTW, the '69-1/2 A12's are all internally balanced.
[Re: dragon slayer]
#3036091
04/22/22 06:26 PM
04/22/22 06:26 PM
Posts: 81 usa
bdgtfb
usa
What is your bell housing number? That dictates Flywheel. Not 100% sure on A12, but I thought your car would have the cast iron bell housing for the 143 Flywheel for external balance. So you use the standard 11" clutch. In 1970 mopar went to the aluminum bellhouse for the 130 tooth with 11" scalloped clutch (10.95" disc). Either will work, but the bellhouse size determines the flywheel and clutch. thanks for the help so far. the bellhousing part number is 28922626 39028 - cast iron.
[Re: bdgtfb]
#3036125
04/22/22 08:37 PM
04/22/22 08:37 PM
6PakBee
North Dakota
Hmm. Govier's book shows a separate number for '68 and '69 for the 11" BB cast iron bell. 2892262 for '68 and 2892626 for '69. I'm not going to stake my life on it but I'm sure they interchange.
[Re: 6PakBee]
#3036160
04/22/22 09:54 PM
04/22/22 09:54 PM
Posts: 81 usa
bdgtfb
usa
Hmm. Govier's book shows a separate number for '68 and '69 for the 11" BB cast iron bell. 2892262 for '68 and 2892626 for '69. I'm not going to stake my life on it but I'm sure they interchange. sorry, my bad. 2892626 is what i should have listed!
[Re: bdgtfb]
#3045804
05/28/22 09:41 AM
05/28/22 09:41 AM
Posts: 959 Chicago
PurpleBeeper
Chicago
So.... you need an "11 inch" clutch and pressure plate. Remove the big spring behind the clutch pedal. I've had good experiences with that centerforce clutch
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Rhinodart]
#3046053
05/29/22 05:34 AM
05/29/22 05:34 AM
Posts: 6,410 Abilene, Texas
fastmark
Abilene, Texas
I would NEVER put a diaphram clutch in a Mopar, just MY personal preference, they were never designed for them... I agree. I had a lady customer who wanted a soft pedal. The release rate on a diaphragm is all wrong for a Mopar. I called McLoed about it and said that’s correct. It was softer, just hard to release slow. I have a customer with a Centerforce and it was better. Two more friends had diaphragm styles and just switched back to a borg and beck. They did not like them because of the fast release.
[Re: Jeremiah]
#3046187
05/29/22 03:07 PM
05/29/22 03:07 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have always used B&B plates or the BB&Long Mk12 adjustable that I use when I raced my car every weekend. I got a deal on a Centerforce II plate a few years ago and I said why not try it. I bought a Mcleod 500 series dual friction disc and with the CF plate this has been the absolute best street clutch I have ever used. But I am not one of those "Mopar or no car" purist snobs. Hell I even had a Ford 9" under my car for a while in my racing days. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3046232
05/29/22 07:00 PM
05/29/22 07:00 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I've run Center Force clutches since they came out and just love them. Have one in my 73 W200 and my 72 Dart. Had them in several other cars too. Have to remove the over cam spring from the pedal assy. For me the only better clutch is the McLeod twin disc that I use behind higher HP motors. My W200 with the popup camper, 64 gal of fuel, John boat and loaded up with gear and people weights in at around 8500#. Climbing over rocks and four wheeling I've abused the crap out of it and it has never failed.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
