A/C issue on 70 e-body???????!!! #303575
04/30/09 09:30 AM
04/30/09 09:30 AM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
I am working on a friends 70 r/t challenger that has a classic auto air compressor, condensor, and evaporator. It has special made braided lines for show that are not from classic auto air, he is also running the serpentine belt setup. The car has a mild built 383, a "be cool" 4 core aluminum radiator, and a set of dual electric fans.
Now for the problem, I went and vac'd the system down and pulled a good strong vacuum on the system, checked it for leaks...none present.
I charged the system with the recommended 24oz of r134 freon, and the fans work, the compressor seems to be working, and i know the expansion valve is working, but the lines at one point felt cold going into the firewall, but no cold air blowing into the car.
I checked the hot water valve, and it IS closed, so i vac'd it back down, and recharged it again and now my gauges show good, but the lines are both warm and the compressor is on, but it is making noise like it could be bad, but what do you guys think??????????
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck 1986 Power Ram 400hp 360 6" lift 1970 Plymouth custom suburban 318 4" drop 1996 Dodge 1500 360 4wd 3" lift North Central Indiana Mopar Club member
Re: A/C issue on 70 e-body???????!!! [Re: swepty] #303576
04/30/09 09:32 AM
04/30/09 09:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
whats the pressures ?
Re: A/C issue on 70 e-body???????!!! [Re: gtx6970] #303577
04/30/09 09:35 AM
04/30/09 09:35 AM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
they were hovering around 20-35 on the low side, and 100-125 on the high, but it is cool here and low humidity, plus the car has a pretty choppy cam so it fluctuates a little.
