Question about my A12 reverse indicator light wire. #3035169
04/19/22 10:24 PM
04/19/22 10:24 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Hi
Can anyone show me where the 4-speed "reverse indicator light" harness routes through the firewall ?
Thanks in advance
Mike
Re: Question about my A12 neutral safety switch harness. [Re: Texican] #3035173
04/19/22 10:48 PM
04/19/22 10:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
confused Hmmmmmm the only one that makes sense is "A". Maybe someone else can help? Reason I say that is my A12 is a 727 auto BUT my '69 GTX is a 4-Speed with a reverse light under the dash AND a tachometer and I "think" both the reverse light wire and the tach wire come through the firewall through the same LARGE hole but up and to the driver's side? Here's an ugly shot of what I think is the hole on the GTX for those wires for the reverse light and tach. Probably wrong on this but hope someone else will chime in.
Mike too grin
Re: Question about my A12 neutral safety switch harness. [Re: A12] #3035175
04/19/22 11:00 PM
04/19/22 11:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hole "B" is not punched on my '69 RR - 4speed with light but no factory tach - and it's an unrestored 17,000-mile car.
Not much help on an AT car, though...
Re: Question about my A12 neutral safety switch harness. [Re: topside] #3035181
04/19/22 11:08 PM
04/19/22 11:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Does your car have the "A" (I don't want to say it but I just have to wink ) hole? biggrin laugh2 laugh2
Re: Question about my A12 neutral safety switch harness. [Re: A12] #3035185
04/19/22 11:44 PM
04/19/22 11:44 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Pun intended smile
I guess it could route through either hole, and maybe the length of the harness would give me a hint.
It may have to route through hole A.
Re: Question about my A12 neutral safety switch harness. [Re: Texican] #3035283
04/20/22 10:24 AM
04/20/22 10:24 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A12 - Hey, it wouldn't be as funny if you'd said "Hole A" !
(My car has TWO A-holes: one in the firewall & one in the driver's seat !)
Hole A is for a heater box stud.
My 4-speed NSS wire runs up over the bellhousing, to near the rt side valve cover, and joins a harness near the harness retaining clip there.
I would think all NSS routing would be the same, for assembly-line reasons, and that B is tach only regardless of transmission.
I could be wrong on that, but it would also dovetail with tach being called out on the body tag so B gets punched/drilled.
Re: Question about my A12 reverse indicator light wire. [Re: Texican] #3037564
04/27/22 11:08 AM
04/27/22 11:08 AM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
The wires will be in two of the open spots in your bulkhead connection, Your service manual will show where the wires will go. The hole marked "B" is for the tach wire only.
Re: Question about my A12 reverse indicator light wire. [Re: Kilrbee] #3037622
04/27/22 02:56 PM
04/27/22 02:56 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Correct...it connects at bulkhead. Pretty sure it is one of the two bottom outside corners. A look at the wiring diagram will clarify it for you.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Question about my A12 reverse indicator light wire. [Re: 70gtx440dana] #3059553
07/15/22 11:05 PM
07/15/22 11:05 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Thanks to all ~
Re: Question about my A12 neutral safety switch harness. [Re: A12] #3064850
08/03/22 10:18 AM
08/03/22 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike too grin
Sorry for the late response ....
Hole A is where the throttle cable comes thru , B is the optional Tach. The reverse lights go thru the bulkhead connected to a wiring harness' empty holes ... same ones as the neutral safety switch for auto trans? ..... check your wiring diagram ...
Re: Question about my A12 neutral safety switch harness. [Re: JohnRR] #3065340
08/04/22 09:52 PM
08/04/22 09:52 PM
Mass
Mike Mancini Offline
Mass
The dash mounted reverse light indicator wire installs into the "Z" terminal in the bulkhead connector.
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
