1970 Chrysler Side Marker Lights #3034385
04/17/22 01:08 PM
04/17/22 01:08 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
Hello,
I am hoping someone can advise me on the proper way to replace the bulb in the front side marker light of a 1970 Chrysler Newport. The only "easy" way that I see to do it is to unscrew the assembly form the outer side of the fender. Unfortunately, it does not want to come off. I'm guessing there is something holding it from behind. There is no direct access to the backside of the assembly to replace the bulb. Do I need to disassemble the fender in order to get this done? I've searched but cannot find anything posted on the 1970 model.
In the event it matters, this is a convertible. Any help with the correct procedure is appreciated.
Thanks,
Paul
1970 Barracuda Convertible
1970 Newport Convertible
1970 Satellite Convertible
1974 'Cuda shell - '71 conversion
1988 Oldsmobile Cutlass w/455
2003 RAM3500 CTD
2007 Caliber R/T AWD
2007 Magnum SRT-8
2016 Chrysler Town & Country
Re: 1970 Chrysler Side Marker Lights [Re: RCKTMN] #3034391
04/17/22 01:26 PM
04/17/22 01:26 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Is it just a side marker ? or is it the larger cornering light ?? If it is just the smaller orange side marker, then you should be able to just unscrew the lens from the outside of the fender (should be two screws holding it on), then you can get to the bulb . . . .
Re: 1970 Chrysler Side Marker Lights [Re: a12rag] #3034395
04/17/22 01:35 PM
04/17/22 01:35 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
It is the basic side marker light.
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: 1970 Chrysler Side Marker Lights [Re: a12rag] #3034398
04/17/22 01:38 PM
04/17/22 01:38 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
It doesn't want to give and I already put a small dent in my attempts to pry it off.
frown
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: 1970 Chrysler Side Marker Lights [Re: a12rag] #3034432
04/17/22 03:38 PM
04/17/22 03:38 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
a12rag,
Do I feel dumb. I guess I've been tinkering with "modern" cars too much. I always assume the worse in design. Once I went about a different way to remove the bezel, the center lense piece popped out. D'oh!
Thanks for your reply.
Paul
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: 1970 Chrysler Side Marker Lights [Re: RCKTMN] #3034458
04/17/22 05:08 PM
04/17/22 05:08 PM
a12rag Offline
a12rag  Offline
no worries !! . . . glad you were able to figure it . . . only need to pull on the lens . ..
