Big block hydraulic roller lifters, which ones are best? #3033168
04/13/22 02:00 PM
04/13/22 02:00 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
As the title says, i need to buy a set of hydraulic roller lifters for my RB build, i'm installing a Trick flow camshaft purchased from 440 Source and they recommend Comp hydraulic rollers.
My engine builder would prefer i avoid Comp lifters even if they are hydraulic rollers. So far i'm leaning towards Hughes lifters.
Your results and recommendations are very appreciated
Re: Big block hydraulic roller lifters, which ones are best? [Re: mxbeep] #3033177
04/13/22 02:12 PM
04/13/22 02:12 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Comp hydraulic rollers are garbage. Had a friend with some in his BB Dart and they made lots of noise. Swapped to Howards.
We used Howards (Morel) and they have been flawless. 7,000 miles over 6 years and hundreds of dragstrip passes.
'63 Dodge 330
11.19 @ 121 mph
Re: Big block hydraulic roller lifters, which ones are best? [Re: GY3] #3033181
04/13/22 02:24 PM
04/13/22 02:24 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
where did you purchase your Howards hydraulic rollers?
all i can find are solid rollers
Re: Big block hydraulic roller lifters, which ones are best? [Re: mxbeep] #3033186
04/13/22 02:30 PM
04/13/22 02:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It's been long enough I honestly don't recall. I bought a lot of stuff from Competition Products but not sure that's where I bought these.
Edit: After looking at their website they show them but they are currently out of stock.
'63 Dodge 330
11.19 @ 121 mph
Re: Big block hydraulic roller lifters, which ones are best? [Re: mxbeep] #3033187
04/13/22 02:30 PM
04/13/22 02:30 PM
WI
mopar873 Offline
mopar873  Offline
WI
Competition Products shows them out of stock, but it's still worth a call as the two businesses are more or less together.
Re: Big block hydraulic roller lifters, which ones are best? [Re: mopar873] #3033204
04/13/22 03:12 PM
04/13/22 03:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Johnson lifters, NOT Johnson hylift
Re: Big block hydraulic roller lifters, which ones are best? [Re: CSK] #3033221
04/13/22 04:08 PM
04/13/22 04:08 PM
an8sec70cuda Offline
I have a set of BB hyd. roller lifters here from Scorpion that I got almost 10 years ago. Got them from Dan (DRAM) because he said they were good quality. I haven't used them so I can't speak on any personal experience.
CHIP
'06 GMC 2500HD LBZ Duramax
