Re: Big block hydraulic roller lifters, which ones are best?
[Re: mxbeep]
#3033177
04/13/22 02:12 PM
04/13/22 02:12 PM
Posts: 4,681 Wichita
GY3
Wichita
Comp hydraulic rollers are garbage. Had a friend with some in his BB Dart and they made lots of noise. Swapped to Howards.
We used Howards (Morel) and they have been flawless. 7,000 miles over 6 years and hundreds of dragstrip passes.
[Re: GY3]
#3033181
04/13/22 02:24 PM
04/13/22 02:24 PM
Posts: 1,624 qc
mxbeep
qc
We used Howards (Morel) and they have been flawless. 7,000 miles over 6 years and hundreds of dragstrip passes. where did you purchase your Howards hydraulic rollers? all i can find are solid rollers
[Re: mxbeep]
#3033186
04/13/22 02:30 PM
04/13/22 02:30 PM
GY3
Wichita
We used Howards (Morel) and they have been flawless. 7,000 miles over 6 years and hundreds of dragstrip passes. where did you purchase your Howards hydraulic rollers? all i can find are solid rollers It's been long enough I honestly don't recall. I bought a lot of stuff from Competition Products but not sure that's where I bought these. Edit: After looking at their website they show them but they are currently out of stock.
[Re: mopar873]
#3033204
04/13/22 03:12 PM
04/13/22 03:12 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Johnson lifters, NOT Johnson hylift
[Re: CSK]
#3033221
04/13/22 04:08 PM
04/13/22 04:08 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
I have a set of BB hyd. roller lifters here from Scorpion that I got almost 10 years ago. Got them from Dan (DRAM) because he said they were good quality. I haven't used them so I can't speak on any personal experience.
