Cometic gasket trim with head installed? #3031958
04/08/22 07:22 PM
04/08/22 07:22 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Figured I'd ask before I remove the heads for the 3rd time. Any way to trim the gasket while assembled? I don't see any way. Should've paid attention to 440 Jim's thread. This is the 3rd pr of Cometic's on this engine. Never had the issue before. #4 and #5 exhaust pushrods hit the center portion of the gasket that doesn't set on the deck itself. Just hangs in the breeze. Any Ideas?
Doug
Re: Cometic gasket trim with head installed? [Re: dvw] #3031960
04/08/22 07:36 PM
04/08/22 07:36 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
with the right tool bend it out of the way
Re: Cometic gasket trim with head installed? [Re: dodger mope] #3031980
04/08/22 08:53 PM
04/08/22 08:53 PM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
Not sure how much room you have or how close you need to get to the side but possibly a knockout punch? Or as mentioned bend it (tapered drift)?
Re: Cometic gasket trim with head installed? [Re: INTMD8] #3032093
04/09/22 12:48 PM
04/09/22 12:48 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Carbide burr. Tape Everything off and let it eat
Re: Cometic gasket trim with head installed? [Re: FastmOp] #3032221
04/09/22 09:48 PM
04/09/22 09:48 PM
Andrews,In. U.S.of A.
67_Satellite Offline
While holding the end of the shop-vac hose as close as possible.
Re: Cometic gasket trim with head installed? [Re: 67_Satellite] #3032242
04/09/22 11:16 PM
04/09/22 11:16 PM
PA
moparacer Offline
moparacer  Offline
PA
No way would I get anywhere near that engine with a carbide burr during assembly..... eek
I have 7/16 pushrods and have always trimmed that center piece off that is basically useless with tin snips before I put them on Doug. Just did it tonight on mine. I think that is the spot you are referring too? Lift the pieces apart and do them separately.
Just pull them back off and get out the tin snips.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Cometic gasket trim with head installed? [Re: FastmOp] #3032336
04/10/22 01:26 PM
04/10/22 01:26 PM
shock tsk
Take the heads off for pushrod clearance grinding wrenchtwocents
Re: Cometic gasket trim with head installed? [Re: Cab_Burge] #3032432
04/10/22 07:59 PM
04/10/22 07:59 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Boy am I dumb. Always think simple. Words to live by. I should pay attention to my own words. This is the 3rd pair of Cometics I've used in this motor. Never had an issue before. Pulled the heads trimmed the gaskets. Clamped the gaskets between two pieces of wood and cut off the excess. Deburred all 5 layers. The stainless center layer is tough. The piece I cut off looked symmetrical. Humm? Cleaned off the RTV from the valley plate. Relubed all the studs. Reinstalled and torqued the heads. Number 5 pushrod still looked odd. upon looking further I see the issue. The motor has off set cups in the intake lifters. I had the #5 lifter pair rotated around with the exhaust and intake lifters swapped. Getting old. Should have investigated further. Anyway is all together except the pan and oil pump.
Doug
Re: Cometic gasket trim with head installed? [Re: dvw] #3032436
04/10/22 08:10 PM
04/10/22 08:10 PM
I've never made any mistakes whistling That I didn't regret later realcrazy
Your still human up Glad you caught it up
Re: Cometic gasket trim with head installed? [Re: Cab_Burge] #3032439
04/10/22 08:21 PM
04/10/22 08:21 PM
Chesterfield Twp. Mi.
John Burdine Offline
Doug, who's mandrel and pulley do you have?
Re: Cometic gasket trim with head installed? [Re: John Burdine] #3032448
04/10/22 08:46 PM
04/10/22 08:46 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
GZ mandrel and front Pulley. My friend Paul made the larger rear alternator pulley. It had a GZ alternator pulley that was smaller in diameter.
Doug
