Milodon single line hose replacement.
#3032111
04/09/22 01:57 PM
04/09/22 01:57 PM
Posts: 1,301 Penna
70satelliteguy
Penna
My single line has seen better days.Just need a new hose. Drips slightly from between base of hose and bolt where it attaches to pan bulkhead. Jegs and Summit want to sell whole single line kit ($500 +)and will ship 6-30-22. Any alternatives ? Anyone have a local shop make up one that will work? Milodon want's $150 for a new one. Mike
Re: Milodon single line hose replacement.
[Re: Clanton]
#3032141
04/09/22 03:39 PM
04/09/22 03:39 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Mike,
Will either of those work? Both are used, not 100% perfect looking, but they don’t leak.
Shorter one is about 21” fitting end to end, and longer one is 24” fitting end to end. They’re both just extras laying around.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: 70satelliteguy]
#3032152
04/09/22 04:35 PM
04/09/22 04:35 PM
birdtracker
use Google to see if you have a Parker hose supply store near you. You can walk in with your old hose and they will duplicate it while you wait. https://www.parker.comBirdtracker
#3032188
04/09/22 06:13 PM
04/09/22 06:13 PM
Posts: 199 TN Hoosier
jb500
TN Hoosier
Is the leak/drip coming from the hose end or the bulkhead fitting?
If the hose is shot and you don't mind using industrial grade materials, then give Hoseandfittings.com a try for a replacement.
The assembly description you want is: 12R14-TB-12FJX-12FJX-18 and the cost should be in the mid $50's for the PTFE hose assembly.
[Re: Dduster]
#3032196
04/09/22 07:54 PM
04/09/22 07:54 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Thank You for all the reply's.It is the hose not the bulkhead. I found a local place that will make them up for you. I will also check out Summit. Thank's Wes but I think the straight line will work easier. Mike
#3032240
04/09/22 11:10 PM
04/09/22 11:10 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Make sure and get Teflon lined AN hose, not rubber or neoprene Are you using the Milidon single line steel pickup? If so is it mounted on the driver side of the oil pan or on the rear of the stock Mopar sump?
#3032254
04/10/22 02:32 AM
04/10/22 02:32 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Thank You for all the reply's.It is the hose not the bulkhead. I found a local place that will make them up for you. I will also check out Summit. Thank's Wes but I think the straight line will work easier. Mike No problem Mike. Good luck.
- A. Einstein
[Re: EvilB1Dart]
#3032279
04/10/22 09:18 AM
04/10/22 09:18 AM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The crimp fittings the industrial hose supply places use are not the correct inside taper to mate with AN fittings. You do not want to go that route.
A few years ago I had what you need - couldn't give the damn thing away !!
#3032523
04/11/22 08:50 AM
04/11/22 08:50 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
"The crimp fittings the industrial hose supply places use are not the correct inside taper to mate with AN fittings. You do not want to go that route." So are you saying that a place like Parker will not be able to make a hose for me that will work? Thanks Mike Just tell them it is a 37 degree AN fitting and not a 45 degree plumbing fitting. They ought to be able to hook you up.
[Re: tubtar]
#3032596
04/11/22 12:59 PM
04/11/22 12:59 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
You can use standard braided hose or even the black nylonhose. IF you run a spring in the line. They sel the springs in all sizes aint rocket science. I have run black lite nylon hose with a spring on pickups for external and dry sumps for YEARS.
