Question about 1971 Satellite/Roadrunner hood #3030385
04/03/22 08:02 PM
04/03/22 08:02 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
The PO included an extra hood when I bought my 1971 Satellite (as in 1st pic, below). Was this hood available on Satellite, Roadrunner and GTX? And is it the hood I would use if I wanted to install an air grabber kit (2nd pic)? Thanks for any info.
Roger
Re: Question about 1971 Satellite/Roadrunner hood [Re: Fab64] #3030416
04/03/22 08:56 PM
04/03/22 08:56 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I sent you a PM.
Re: Question about 1971 Satellite/Roadrunner hood [Re: Fab64] #3030551
04/04/22 12:13 PM
04/04/22 12:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by Fab64
Hi all,
Roger
Yes , the base 71 satellite hood was used to make the 71 air grabber hood.
Re: Question about 1971 Satellite/Roadrunner hood [Re: Fab64] #3030681
04/04/22 06:30 PM
04/04/22 06:30 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
To answer your original question, the Air Grabber was not available on Sattelites - only on RR or GTX models.
Re: Question about 1971 Satellite/Roadrunner hood [Re: Sunroofcuda] #3030760
04/04/22 10:21 PM
04/04/22 10:21 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I sem to remember that my son had a RR with a 360 4bbl, and an air grabber hood, was that an option??
Thanks, Joe
Re: Question about 1971 Satellite/Roadrunner hood [Re: jlatessa] #3030973
04/05/22 03:27 PM
04/05/22 03:27 PM
IMGTX Offline
IMGTX  Offline
Thanks, Joe
I do not believe the 360 was available until late 73 or 74 which would have been after the air grabber had stopped being used.
It could be that he had a 71 Air Grabber and someone replaced the 340 with a 360. Or maybe as time progressed the size of the engine got confused.
Re: Question about 1971 Satellite/Roadrunner hood [Re: IMGTX] #3031026
04/05/22 07:19 PM
04/05/22 07:19 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks for the replies, everyone. beer
Roger
Re: Question about 1971 Satellite/Roadrunner hood [Re: IMGTX] #3031028
04/05/22 07:24 PM
04/05/22 07:24 PM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
Quote
air grabber kit
Where are you getting this "kit"? The under side of the stock hood is different than the air grabber. The air grabber has a different inner frame structure for the air cleaner. I have both these hoods, The air grabber water got into and rusted out the lower/inner frame structure. My plan is to cut the opening/holes in the outer hood and cut the inner section of the air grabber(around the air cleaner) and weld it to the good(rust free) hood. I suppose you could cut up the stock hood but it wouldn't look factory unless you had the lower frame section around the air cleaner.
Re: Question about 1971 Satellite/Roadrunner hood [Re: Moparite] #3031049
04/05/22 08:43 PM
04/05/22 08:43 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Ok, just to clarify, I'm not planning to add an Air Grabber kit to my hood.
Re: Question about 1971 Satellite/Roadrunner hood [Re: Fab64] #3031083
04/05/22 10:47 PM
04/05/22 10:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
an AIRGRABBER hood isn't just a flat Satellite hood with the insert added
the top sheetmetal is the "flat" hood & the inner sheetmetal is from a "bulge" hood
Re: Question about 1971 Satellite/Roadrunner hood [Re: 6bblgt] #3031090
04/05/22 11:44 PM
04/05/22 11:44 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks for clarifying. I guess I made a bad assumption when I saw the air grabber and bulge kits that are offered for sale.
Re: Question about 1971 Satellite/Roadrunner hood [Re: Fab64] #3032082
04/09/22 12:12 PM
04/09/22 12:12 PM
rust belt
rust belt
The "bulge" is actually made from fiberglass.
https://www.musclecarparts.cc/shop/item.aspx/1971-72-roadrunner-gtx-air-grabber-kit/8147/
And this kit does NOT come with the "bulge". Have seen mixed reviews on the reproductions.
https://aarqualityfiberglass.com/product/bubble-door-road-runner-1971-1972-air-grabber-center/
