Re: Question about 1971 Satellite/Roadrunner hood
[Re: Fab64]
#3030551
04/04/22 12:13 PM
04/04/22 12:13 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Hi all,
The PO included an extra hood when I bought my 1971 Satellite (as in 1st pic, below). Was this hood available on Satellite, Roadrunner and GTX? And is it the hood I would use if I wanted to install an air grabber kit (2nd pic)? Thanks for any info.
Roger Yes , the base 71 satellite hood was used to make the 71 air grabber hood.
[Re: Fab64]
#3030681
04/04/22 06:30 PM
04/04/22 06:30 PM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
To answer your original question, the Air Grabber was not available on Sattelites - only on RR or GTX models.
[Re: Sunroofcuda]
#3030760
04/04/22 10:21 PM
04/04/22 10:21 PM
Posts: 1,317 Ohio
jlatessa
Ohio
I sem to remember that my son had a RR with a 360 4bbl, and an air grabber hood, was that an option??
Thanks, Joe
[Re: jlatessa]
#3030973
04/05/22 03:27 PM
04/05/22 03:27 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Thanks, Joe I do not believe the 360 was available until late 73 or 74 which would have been after the air grabber had stopped being used. It could be that he had a 71 Air Grabber and someone replaced the 340 with a 360. Or maybe as time progressed the size of the engine got confused.
[Re: 6bblgt]
#3031090
04/05/22 11:44 PM
04/05/22 11:44 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
an AIRGRABBER hood isn't just a flat Satellite hood with the insert added
the top sheetmetal is the "flat" hood & the inner sheetmetal is from a "bulge" hood Thanks for clarifying. I guess I made a bad assumption when I saw the air grabber and bulge kits that are offered for sale.
