a12 hood #3027882
03/26/22 08:25 PM
03/26/22 08:25 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Who makes a good repo A12 hood? Also does anyone make a bolt one using factory hood hinges ? Thanks Guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: a12 hood [Re: stickman] #3029343
03/31/22 09:23 PM
03/31/22 09:23 PM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
I have no experience with this company or its products....just giving you a link.
http://www.usbody.com/
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: a12 hood [Re: stickman] #3029382
04/01/22 12:57 AM
04/01/22 12:57 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Year One in the past made the best and closest to the original A12 Lift-Off-Hood IMO. In fact it was so close to the original that it was passed off I'm sure as an original many times. The only way to tell a Yr1 from an original was IT WAS WAY BETTER MADE as far as the under hood fiberglass mat build quality laugh2 The original hood's underside fiberglass looks like I would have done it in my garage, not very nice. Anyway I just checked to see if Year One still sold an A12 hood and they do have one listed but not available at this time. It's been a while since I've checked Yr1 or have heard anything about this hood or if it is like the one they sold since the 90's ??? Here's the link. Let us know if you find anything out about the Year One A12 hood. Oh and also the Year One A12 hood was not the best hood to add hood hinges to but I think it's been done. There's a thin A12 style hood that used to be made by a company in Cocoa Florida (forgot the name) that is really nice and was actually made to accept standard hood hinges.
Year One A12 hood link:
https://www.yearone.com/Product/chrysler-b-body/lh1002#prettyPhoto
Mike
Re: a12 hood [Re: A12] #3029476
04/01/22 11:02 AM
04/01/22 11:02 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Check with AAR Fiberglass in FL - Titusville, IIRC.
Had one of their hoods (A12 style on a Duster) - it was pretty nice and accepted hinges & latch.
Re: a12 hood [Re: topside] #3029554
04/01/22 01:53 PM
04/01/22 01:53 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yes up that's the one in Florida I was trying to remember, really nicely made and made for hood hinges too.
Re: a12 hood [Re: topside] #3029755
04/01/22 08:25 PM
04/01/22 08:25 PM
oregon
greendart408 Offline
oregon
Now called stinger......I have one of their 340 buldge hoods on my og 69, 340 swinger. It’s a mint piece. Their quality is exceptional is what I’m getting at. Good stuff
Re: a12 hood [Re: stickman] #3029797
04/01/22 10:22 PM
04/01/22 10:22 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: a12 hood [Re: Ply72rr] #3030012
04/02/22 04:45 PM
04/02/22 04:45 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I saw one bad good from them. Ask Daycona (Mike about Stinger he has looked at plenty)
I think he knows of a better source than the new AAR under Stinger.
But AAR may also be your only option.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: a12 hood [Re: A12] #3030120
04/03/22 12:04 AM
04/03/22 12:04 AM
IL us
I
ink Offline
ink  Offline
I
IL us
Mike
I have two original A12 hoods and just pick up a used year one hood that still has sticker on it never been on car. IMO.the year one is in no way better than my originals!!!!!
Re: a12 hood [Re: ink] #3030129
04/03/22 01:09 AM
04/03/22 01:09 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I said the UNDERSIDE was way better made than the original not that the Year One was better. I have both and to the unknowing I will bet they would pick the Year One as being the original hood because of the underside better "looking" finish.
Quote
Guess which one is the original and which is the Year One reproduction wink
Re: a12 hood [Re: A12] #3030188
04/03/22 10:47 AM
04/03/22 10:47 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Hi A12, where are you located in NE Ohio?
I live in Kirtland and I need to cut the hole in my glass hood for the scoop.
This is a hood for our 70 Charger 6-pak.
If you could make a template or give me some measurements of the offset
from centerline and back edge so I don't bungle the opening, it would be greatly appreciated.
If you do a template, I could pick it up.
Thanks, Joe
Re: a12 hood [Re: jlatessa] #3030345
04/03/22 05:50 PM
04/03/22 05:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanks, Joe
Where to start? I'm assuming you are going to be using the large oval air filter like on the Hemi and Six Pack cars? Next is that the hood scoop as you know is centered left to right on the hood but how far back from the front your scoop will need to go is the question. The how far back the scoop is on a Super Bee versus a Road Runner is I think an inch or so different from what I know so using an A12 Road Runner hood as a reference may not bee (pun) correct for your Charger??. If I were cutting a hole into your Charger's hood I would probably take your air filter big oval COVER and flip it upside down with the concaved shape up so if I lowered the hood onto it then it would touch the underside of the hood. If it didn't touch I would shim it until it just did. Then I would put some grease or maybe the stringline blue chalk or something that would leave a mark as to where the air filter cover touches the underside of the hood. Then I would work from go from there to center the hood scoop front to rear as the left to right is a given. Here are some illustrations/drawings that may help. Some are exact copies of factory A12 documents and some as you can see are ones I did to show the underside opening is NOT centered.
MikeR
Hood_location_with_lines_orig_hood_underside_A.jpgHood_Pin_location_RR1.jpgHood_Pin_location_RM_Road_Runner_1969_LOH_MikeR_002.jpgHood_Pin_location_WM_Super_Bee_1969_LOH_MikeR_0S_002.jpg
Re: a12 hood [Re: A12] #3030456
04/04/22 12:15 AM
04/04/22 12:15 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Correct Mike, using a std. 6 pak air cleaner set up, no A-12 base, That may come later.
I know the scoop is centered vs. the the hood opening being over the engine.
I THINK all B bodies had the same firewall and fender to fender dimensions in that 68-70 time span???
I you can give me the dimension from the back of the hood opening to the back of the hood and the width
and length of the hole, that will get me close enough.
the schematic you sent will definitely help with the 4 pin placements.
If I'm missing any other particulars, please fill me in.
Thank you very much for the help, Joe
440-37six zero 97eight
PS I think the different front pin locations are due to the grill design and maybe hood length
Re: a12 hood [Re: jlatessa] #3030465
04/04/22 06:07 AM
04/04/22 06:07 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
BTW maybe this is a coincidence but the '69 Super Bee and Road Runner have a difference in wheelbase of almost the exact same distance.......probably only a co-inky-dink laugh2
MikeR
Re: a12 hood [Re: A12] #3030734
04/04/22 09:31 PM
04/04/22 09:31 PM
IL us
I
ink Offline
ink  Offline
I
IL us
Quote
if only it wasn't so hard for me to post pics !!!! I will say my hood has been painted on under side . I had asked the painter not to paint over the green but he forgot ;( i still say my original is nicer than my year one !!! top and bottom maybe its because i have super bee hoods ??? and everyone knows super bees are nicer than roadrunners !!
Re: a12 hood [Re: ink] #3030869
04/05/22 10:47 AM
04/05/22 10:47 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Quote
Of course! grin
'63 Dodge 330
11.19 @ 121 mph
Re: a12 hood [Re: GY3] #3030871
04/05/22 10:51 AM
04/05/22 10:51 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by GY3
Quote
Of course! grin
Nicer but sadly not as quick wink
Re: a12 hood [Re: GY3] #3031137
04/06/22 08:58 AM
04/06/22 08:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Quote
Of course! grin
grin up
