Acceptable Gear Pattern? #3027284
03/25/22 06:02 AM
03/25/22 06:02 AM
Auburn, PA
Tim B Offline OP
Tim B  Offline OP
Auburn, PA
Hi All,
I was wondering if someone could take a look at this ring and pinion pattern and let me know what you think? I have patters for both .030 pinion shim and .025 pinion shim. Both backlash was set to .006 to .010.
Thanks in advance!
Tim
Inked20220323_180126_LI.jpgInked20220323_180157_LI.jpgInked20220324_170302_LI.jpgInked20220324_170309_LI.jpg
Re: Acceptable Gear Pattern? [Re: Tim B] #3027327
03/25/22 10:23 AM
03/25/22 10:23 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
IMHO, I would try a .033-.035 shim. The drive side could be closer to the 'toe' on the drive side, which should bring your coast side more towards the middle of the tooth.
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: Acceptable Gear Pattern? [Re: GTX5877] #3027829
03/26/22 06:20 PM
03/26/22 06:20 PM
Auburn, PA
Tim B Offline OP
Tim B  Offline OP
Auburn, PA
Here is with .035 shim.....
Re: Acceptable Gear Pattern? [Re: Tim B] #3027881
03/26/22 08:24 PM
03/26/22 08:24 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi Tim , I like the .030 shim for BOTH your coast and drive patterns pictures . Plus the base 489 pinion shim to start with IS a .030 , if thats what you are working on . A 742 you usually start with a .090 shim . drive Ronnie
Re: Acceptable Gear Pattern? [Re: 1969ronnie] #3028088
03/27/22 03:59 PM
03/27/22 03:59 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you have a combo that you could come up with .033 shim pack ? If not then I like the .030 pattern twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Acceptable Gear Pattern? [Re: fourgearsavoy] #3028808
03/29/22 07:58 PM
03/29/22 07:58 PM
Auburn, PA
Tim B Offline OP
Tim B  Offline OP
Auburn, PA
Okay, got it all buttoned up. About 18-19 in/lbs pinion turning torque.
Does 29-30 in/lb turning torque with the center section fully assembled sound right? I'm right at .006-.007" backlash.
Re: Acceptable Gear Pattern? [Re: Tim B] #3028845
03/29/22 09:45 PM
03/29/22 09:45 PM
Rittman Ohio
Rittman Ohio
Does 29-30 in/lb turning torque with the center section fully assembled sound right? I'm right at .006-.007" preload.
Sounds about right for a 742 case but a 489 should have a little less pre load than that. I'm not sure why though shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Acceptable Gear Pattern? [Re: fourgearsavoy] #3028953
03/30/22 11:29 AM
03/30/22 11:29 AM
Auburn, PA
Tim B Offline OP
Tim B  Offline OP
Auburn, PA
Apologies, i meant .006 - .007 backlash not preload.
