Peter Wille's 71 Cuda #3026373
03/22/22 01:10 PM
03/22/22 01:10 PM
MN
JERICOGTX Offline OP
MN
I've probably posted this before, but does anyone know Peter personally? I'd like to ask some questions about his combination.
https://www.youtube.com/watch?v=QlfRBLYcKi8
Thanks,
69 GTX 68 Road Runner
Re: Peter Wille's 71 Cuda [Re: JERICOGTX] #3026400
03/22/22 02:26 PM
03/22/22 02:26 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Thanks,
He's somewhat local to me, we race at the same track. You can send me a PM with your contact and i can send it to him.
Re: Peter Wille's 71 Cuda [Re: JERICOGTX] #3026520
03/22/22 07:50 PM
03/22/22 07:50 PM
Mo.
racerx Offline
racerx  Offline
Mo.
That's a fast A$$ car up
Re: Peter Wille's 71 Cuda [Re: racerx] #3026540
03/22/22 08:30 PM
03/22/22 08:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2
Re: Peter Wille's 71 Cuda [Re: rickraw] #3026996
03/24/22 08:38 AM
03/24/22 08:38 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Back when I saw the dyno vids, I have to admit, I didn't believe the numbers. But the car does run well, when it puts down a good pass so, he can't be too far off IMO.
Re: Peter Wille's 71 Cuda [Re: HardcoreB] #3027027
03/24/22 10:38 AM
03/24/22 10:38 AM
MN
MN
Where are the dyno videos?
Never mind. Found it.
https://www.youtube.com/watch?v=p7mjI9yj128
Very impressive. I'm more excited, as this engine is very similar to mine. Same Stroke, and bore. Anyone know what the Edelbrock Victors flow CNC ported by Hughes? I have the 345CNC -1's.
Re: Peter Wille's 71 Cuda [Re: JERICOGTX] #3027128
03/24/22 05:11 PM
03/24/22 05:11 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
That thing is bad! punkrocka
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Peter Wille's 71 Cuda [Re: an8sec70cuda] #3027140
03/24/22 06:06 PM
03/24/22 06:06 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
His 1000hp NA big block on the dyno at his place
Re: Peter Wille's 71 Cuda [Re: JERICOGTX] #3027145
03/24/22 06:18 PM
03/24/22 06:18 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Wow!! After watching that with my foot in a boot from surgery, It sure give me the itch to get well and lay some rubber.
Re: Peter Wille's 71 Cuda [Re: jwb123] #3027544
03/25/22 08:30 PM
03/25/22 08:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That's the quickest Victor headed car I've seen by far. The next closest would be Jeff Frees 68 Cuda N/SS car touched the 8's at Bradenton at similar weight.
Doug
Re: Peter Wille's 71 Cuda [Re: dvw] #3027680
03/26/22 09:51 AM
03/26/22 09:51 AM
MN
MN
Doug
I had no idea the Victor heads could flow that. Hughes website shows they flow 400cfm at .800. That is the same as a CNC365 572-13 head from INDY. My machinist built a 572 with 572-13 heads, and it made just a touch over 1000hp. My engine has less compression, and INDY 345CNC -1’s. If it can make 900hp, I’ll be more than happy. I’m almost 400lbs lighter than his Cuda as well.
Re: Peter Wille's 71 Cuda [Re: JERICOGTX] #3027751
03/26/22 12:43 PM
03/26/22 12:43 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I don't think that the flow #s of the MW Victor, Hughes modified heads are the big issue here. The obstacle seems to be calculating and obtaining the correct components to reliably allow the heads to perform up to their actual capabilities. Hughes claims nearly 400cfm intake flow around .700-.800" lift. Shouldn't be hard to make 800hp with that, but I have no way to prove or disprove these numbers as I never had my heads independantly flowed when they returned. Only had valve job checked by Nelson Competition and his only suggestion was to put another .0005" in the valve guide clearance for comfort. These heads required 4.50" Cometics on my 4.350" bore motor, the rocker shaft stud anchoring mod., B3 Racing geometry modification (optional), and a brain & wallet taxing adventure to get a 1.625" dia. valve spring to work on this solid roller cam engine. Big pushrods w/modified push rod holes also. I hope it was worth it. The larger bore gaskets were needed because Hughes porting program lays the chamber back near the valves also requiring the head deck surface to be cut, restoring the75cc volume. Rocker effective ratio with Hughes rockers and B3 geo. correction, 1.5's became 1.45's and 1.6's became 1.55's. Combine this with a mis-spec'd used but good condion roller cam, and I had to trash the 1.5 rockers for a new set of 1.6's. Went from a presumed .690" lift to an actual .638" with 1.5 advertised rockers (gross lift). Cam was said to be .460'lobe lift but was actually 440" lobe lift. I am not saying these heads don't make power, just as anyone knows who have used them, they are a tremendous amount of work to get to their potential. If you don't already have them there are much easier starting points, in my opinion. I got them and am going forward. The work is done ,the test is coming. Woulda, coulda, shoulda! Bill
Re: Peter Wille's 71 Cuda [Re: an8sec70cuda] #3028619
03/29/22 10:27 AM
03/29/22 10:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As is the driver, and it's got a man peddle too boot.
Re: Peter Wille's 71 Cuda [Re: JohnRR] #3028631
03/29/22 10:57 AM
03/29/22 10:57 AM
They need to fix the siphoning out of the squirters at WOT to help keep the AFR consistent twocents
Probably a Dam Best Carb, maybe not: confused:
Re: Peter Wille's 71 Cuda [Re: Cab_Burge] #3029127
03/31/22 09:18 AM
03/31/22 09:18 AM
MN
MN
Just looked those up, as I've never heard of them. Yikes. Not cheap at all...
Re: Peter Wille's 71 Cuda [Re: JERICOGTX] #3029212
03/31/22 01:38 PM
03/31/22 01:38 PM
I'm sure Dominic, Thumperdart, can build a better custom carb than they can scope
I had a customer in Boise, ID that I built a 551 C.I. B1 bracket motor for that had two Dam Best dominator type carbs, a 1050 CFM and the bigger one, 1450 CFM maybe confused, built for the B1 motor that didn't work worth a hoot no matter how we jetted it whiney: The 1050 worked okay but not excellent work
Re: Peter Wille's 71 Cuda [Re: Cab_Burge] #3029216
03/31/22 01:50 PM
03/31/22 01:50 PM
MN
MN
Dom will be getting my business when I'm ready to pull the trigger on a different carb.
Re: Peter Wille's 71 Cuda [Re: dvw] #3029243
03/31/22 02:58 PM
03/31/22 02:58 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Doug
Have a small tire dart I help out with in westcoast of canada, on a 275 it has been 4.73@147. Car had a glass hood and trunk, that's it. Victor head with 2 kits.
Re: Peter Wille's 71 Cuda [Re: cuda499] #3029291
03/31/22 06:11 PM
03/31/22 06:11 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
He sure understands his body in that seat. You can see he has the feel for what is happening when the Cuda has the front wheels in the air. Nice Job driving that Cuda.
1971 HEMI E BODY REGISTRY
Re: Peter Wille's 71 Cuda [Re: hemicar1971] #3029386
04/01/22 01:08 AM
04/01/22 01:08 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i know Peter he called me last week and i forgot to call him back. All of Peters stuff runs amazingly well. He bulds some awesome converters as well.
