CRAGAR LUG NUT SIZE #3027130
03/24/22 05:18 PM
03/24/22 05:18 PM
Amherst
P
plumcrzyTA Offline OP
P
Amherst
I JUST GOT SOME CRAGAR SS WHEELS 15X8 5X4 # 1521913402B FOR MY 68 BARRACUDA (DON"T HAVE THE CAR YET)DOES ANYBODY KNOW WHAT LUG NUTS GO WITH THEM THANK YOU!!
Re: CRAGAR LUG NUT SIZE [Re: plumcrzyTA] #3027149
03/24/22 06:23 PM
03/24/22 06:23 PM
CA
crackedback Offline
crackedback  Offline
CA
Those wheels have been a mixed bag regarding which lug to use.
If they are new in box, check the lit with them. If not, snap a picture of the lug area and call cragar. Having the right and left deal might pose an issue as well.
Re: CRAGAR LUG NUT SIZE [Re: crackedback] #3027196
03/24/22 07:30 PM
03/24/22 07:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You have to pay attention to the shank size - diameter & depth.
Different "mag" wheels require different shank sizes, and nothing's better than measuring yours.
Re: CRAGAR LUG NUT SIZE [Re: topside] #3027253
03/24/22 11:11 PM
03/24/22 11:11 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Older Cragars have shank lug nuts, newer ones use typical conical lug nuts, so what was said above, take a picture of them and post it here... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: CRAGAR LUG NUT SIZE [Re: Rhinodart] #3027285
03/25/22 06:05 AM
03/25/22 06:05 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No one can answer this question.
If it's stock 68 brakes or later disc brake swap will matter.
Until you have the car and can verify wheel stud bolt circle and diameter you will be guessing. Remember, stock is has 10 left hand thread studs and 10 right hand thread studs and finding proper LHT nuts can be tough.
IIRC, stock is has 7/16 studs.
Re: CRAGAR LUG NUT SIZE [Re: Sniper] #3027328
03/25/22 10:26 AM
03/25/22 10:26 AM
Amherst
P
P
Amherst
GREAT THX EVERYBODY FOR YOUR IMPUT IT REALLY HELPED,AND YOUR RIGHT I SHOULD WAIT TILL I GET THE CAR TO BE SURE,.WITH SUPPLY SHORTAGES AND OF COURSE GETTING A LITTLE TOO ANXIOUS!!!!!!! DOES"T HELP LOL
Re: CRAGAR LUG NUT SIZE [Re: plumcrzyTA] #3027359
03/25/22 11:57 AM
03/25/22 11:57 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cragar #1521913402B has a conical seat and a '68 A-body will need a 7/16"-20 conical lug nuts, LH and RH.
Re: CRAGAR LUG NUT SIZE [Re: John_Kunkel] #3027374
03/25/22 12:26 PM
03/25/22 12:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
According to Cragar, it needs "Mag lugs nuts with Cragar washers"
https://www.cragarwheel.com/wheels/product-detail/series-0861-ss/
Re: CRAGAR LUG NUT SIZE [Re: Sniper] #3027381
03/25/22 12:57 PM
03/25/22 12:57 PM
CA
crackedback Offline
crackedback  Offline
CA
He clearly mentioned 5x4 pattern. So later brakes are not in the equation.
Just a guess, the wheels won't likely require that uni-lug nonsense other wheels have as they are drilled single pattern.
Someone on another site just had issues with the suggested lug and what was actually needed on a cragar wheel purchase. There are a couple different series of these S/S wheels in production.
Re: CRAGAR LUG NUT SIZE [Re: crackedback] #3027383
03/25/22 01:08 PM
03/25/22 01:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
He doesn't have the car, until he does and can verify no one's been playing with the brakes, who knows? Too many people will put the stock brakes off a 74 A body onto a 68 A body and still think it's "stock". Trust but verify, lol.
Re: CRAGAR LUG NUT SIZE [Re: Sniper] #3027387
03/25/22 01:22 PM
03/25/22 01:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Which differs from https://www.summitracing.com/parts/crr-61c5854
Should be obvious to OP which STYLE is needed. shruggy
Re: CRAGAR LUG NUT SIZE [Re: John_Kunkel] #3027392
03/25/22 01:28 PM
03/25/22 01:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
plumcrzyTA please turn off the caps. it's like yelling at us. Thanks
Re: CRAGAR LUG NUT SIZE [Re: stumpy] #3027414
03/25/22 02:34 PM
03/25/22 02:34 PM
Some (sensitive) people thank that, I don't grin stirthepot devil
Re: CRAGAR LUG NUT SIZE [Re: Cab_Burge] #3027477
03/25/22 05:05 PM
03/25/22 05:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Considering 99% of the posters here use lower case in posts, including you, it would seem to be a generally accepted standard. shruggy
Re: CRAGAR LUG NUT SIZE [Re: John_Kunkel] #3027612
03/25/22 11:29 PM
03/25/22 11:29 PM
BlueRacer69 Offline
BlueRacer69  Offline
Correct. Unless if someone has changed the left side of the car to right hand studs sometime in the past.
Re: CRAGAR LUG NUT SIZE [Re: BlueRacer69] #3028912
03/30/22 09:03 AM
03/30/22 09:03 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
If you need 7/16 lugs PM me here. I think I have some new ones laying around that I never used.
Re: CRAGAR LUG NUT SIZE [Re: plumcrzyTA] #3074609
09/05/22 09:51 PM
09/05/22 09:51 PM
Walton, Indiana
TimS Offline
TimS  Offline
Walton, Indiana
What lug nuts did you end up using for your Cragar application? I also have a 68 Barracuda with stock RH/LH studs and are going to use the same part number Cragar you reference.
Thanks !!
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
