Re: CRAGAR LUG NUT SIZE
[Re: plumcrzyTA]
#3027149
03/24/22 06:23 PM
03/24/22 06:23 PM
Posts: 2,076 CA
crackedback
CA
I JUST GOT SOME CRAGAR SS WHEELS 15X8 5X4 # 1521913402B FOR MY 68 BARRACUDA (DON"T HAVE THE CAR YET)DOES ANYBODY KNOW WHAT LUG NUTS GO WITH THEM THANK YOU!! Those wheels have been a mixed bag regarding which lug to use. If they are new in box, check the lit with them. If not, snap a picture of the lug area and call cragar. Having the right and left deal might pose an issue as well.
[Re: plumcrzyTA]
#3027359
03/25/22 11:57 AM
03/25/22 11:57 AM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Cragar #1521913402B has a conical seat and a '68 A-body will need a 7/16"-20 conical lug nuts, LH and RH.
[Re: Sniper]
#3027381
03/25/22 12:57 PM
03/25/22 12:57 PM
Posts: 2,076 CA
crackedback
CA
No one can answer this question.
If it's stock 68 brakes or later disc brake swap will matter.
Until you have the car and can verify wheel stud bolt circle and diameter you will be guessing. Remember, stock is has 10 left hand thread studs and 10 right hand thread studs and finding proper LHT nuts can be tough.
IIRC, stock is has 7/16 studs. He clearly mentioned 5x4 pattern. So later brakes are not in the equation. Just a guess, the wheels won't likely require that uni-lug nonsense other wheels have as they are drilled single pattern. Someone on another site just had issues with the suggested lug and what was actually needed on a cragar wheel purchase. There are a couple different series of these S/S wheels in production.
[Re: crackedback]
#3027383
03/25/22 01:08 PM
03/25/22 01:08 PM
Posts: 6,252 nowhere
Sniper
nowhere
IIRC, stock is has 7/16 studs. He clearly mentioned 5x4 pattern. So later brakes are not in the equation. Just a guess, the wheels won't likely require that uni-lug nonsense other wheels have as they are drilled single pattern. He doesn't have the car, until he does and can verify no one's been playing with the brakes, who knows? Too many people will put the stock brakes off a 74 A body onto a 68 A body and still think it's "stock". Trust but verify, lol.
[Re: John_Kunkel]
#3027612
03/25/22 11:29 PM
03/25/22 11:29 PM
Posts: 729 Michigan
BlueRacer69
Cragar #1521913402B has a conical seat and a '68 A-body will need a 7/16"-20 conical lug nuts, LH and RH. Correct. Unless if someone has changed the left side of the car to right hand studs sometime in the past.
[Re: plumcrzyTA]
#3074609
09/05/22 09:51 PM
09/05/22 09:51 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
I JUST GOT SOME CRAGAR SS WHEELS 15X8 5X4 # 1521913402B FOR MY 68 BARRACUDA (DON"T HAVE THE CAR YET)DOES ANYBODY KNOW WHAT LUG NUTS GO WITH THEM THANK YOU!! What lug nuts did you end up using for your Cragar application? I also have a 68 Barracuda with stock RH/LH studs and are going to use the same part number Cragar you reference. Thanks !!
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
