1973 Challenger Front Sway Bar Question #3024137
03/15/22 10:08 AM
03/15/22 10:08 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning Everyone,
I am rebuilding the front suspension in a 1973 Challenger. I went to put the front sway bar in and
noticed that there are no lower control arm brackets to connect the sway bar links to. Is this normal
in a 73?
I am a little worried as I put a 440 in the car, will this be a problem if I don't install one?
Thanks,
Re: 1973 Challenger Front Sway Bar Question [Re: jim6346] #3024151
03/15/22 10:50 AM
03/15/22 10:50 AM
IMGTX Offline
IMGTX  Offline
I would want one. Having a car without a sway bar is like steering a boat
Back in those days sway bars were an option. Usually included in performance or tow packages but many cars just didn't get them.
It is pretty easy to get a new pair of Lower Control Arms (LCA) for the E-bodies. 66 (Maybe older) to 72 B Body or any 70-74 E body will swap LCA's.
I can't find the drawing now but a while back I posted a drawing of the brackets. They an be fabbed pretty easy and welded to the LCA's. Another option is aftermarket sway bar companies make bars that clamp to the strut rod or have a bracket that bolts to the shock mount bolt.
Re: 1973 Challenger Front Sway Bar Question [Re: IMGTX] #3024195
03/15/22 12:37 PM
03/15/22 12:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think places like Firm Feel sell replacement brackets that you can weld to your control arms.
Re: 1973 Challenger Front Sway Bar Question [Re: burdar] #3024197
03/15/22 12:44 PM
03/15/22 12:44 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Firm Feel has them, but they don't look like oem. They bolt or weld on either way I think.
Also here for weld-on type. https://www.hotchkis.net/hotchkis-built-better-bracket-new-control-arm-sway-bar-mount-body/
Re: 1973 Challenger Front Sway Bar Question [Re: Neil] #3024788
03/17/22 09:32 AM
03/17/22 09:32 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I have decided to add the sway bar and have ordered the brackets from Hotchkiss.
Thanks everyone.
