SHAKER BASE PLATE STUDS #3023993
03/14/22 03:50 PM
03/14/22 03:50 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Does anyone sell or reproduce the studs for shaker base plate?
Thank you for any information.
Re: SHAKER BASE PLATE STUDS [Re: sbcjd] #3024014
03/14/22 05:44 PM
03/14/22 05:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Member Dayclona (Mike) posted this a few years back:
"If you have access to McMaster Carr, meaning you need a business account to purchase,...McMaster has "weld studs", steel, PN# 93865A235 this should spec out for the Shaker application, the weld head is just under 5/8" in diameter, .083 thick, 1/4"-20 thread 1" long, pkg of 100, $14.58"
'63 Dodge 330
11.19 @ 121 mph
Re: SHAKER BASE PLATE STUDS [Re: GY3] #3024019
03/14/22 06:03 PM
03/14/22 06:03 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I think he probably wants the early ones the factory used shown on the left with the 5 over S B markings.
Re: SHAKER BASE PLATE STUDS [Re: mccannix] #3024023
03/14/22 06:30 PM
03/14/22 06:30 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Well, I do not have a business account with McMaster so I cannot buy from them. It would be nice to find some originals as pictured from Terry but I have never seen those advertised for sale.
You go to Ebay and it seems just about every bolt has been reproduced but no shaker studs. Is there some alternative stud that can be used?
Thank you.
Re: SHAKER BASE PLATE STUDS [Re: sbcjd] #3024031
03/14/22 07:07 PM
03/14/22 07:07 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
If you dont mind scrounging around, Chrysler used these on lots of other applications.
26 inch B and C-body radiator straps....bottom bracket on some window applications, and E-body window part.
Many other applications as well where I have seen them, just have to remember where.
Tough part is separating them from the metal
Re: SHAKER BASE PLATE STUDS [Re: sbcjd] #3024081
03/14/22 11:15 PM
03/14/22 11:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thank you.
Years back, you needed to have a business account in order to purchase thru McMaster Carr, not so anymore, you can open your own account or purchase/pay directly, no minimum purchase either, McMaster Carr has quite a large inventory, also offer assistance in finding items they don't offer, most items ship within 1-3 days unless noted on your order...Mike G
Re: SHAKER BASE PLATE STUDS [Re: DAYCLONA] #3024170
03/15/22 11:30 AM
03/15/22 11:30 AM
moparx Offline
moparx  Offline
what would one use to weld these studs similar to factory mounting ?
beer
Re: SHAKER BASE PLATE STUDS [Re: moparx] #3024194
03/15/22 12:37 PM
03/15/22 12:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
There in lies the problem for most restorers wanting factory spot welded studs, they don't have the 3 phase powered water cooled automotive resistance spot frame welder and assorted electrode adapter ends needed.....
Re: SHAKER BASE PLATE STUDS [Re: sbcjd] #3024218
03/15/22 01:49 PM
03/15/22 01:49 PM
Woodbridge
Tommy The Chryco Offline
Woodbridge
I have some if you need them. Not with the numbers just what are on the repro parts.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: SHAKER BASE PLATE STUDS [Re: Tommy The Chryco] #3024420
03/15/22 10:45 PM
03/15/22 10:45 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Without a special holding fixture, any attempt to spot weld them on would disrupt (i.e. mar) the critical surface markings.
I'd imagine a fixture could be rigged up by a shop, but for only a few welds not worth it to them.
Possibly braze them on. Then stamp on the markings
