Nitrous Express Mainline System #3020476
03/03/22 12:26 PM
03/03/22 12:26 PM
St.Pete,Florida
lancer493 Offline OP
St.Pete,Florida
Have any here used this system before? Part#ML1001. Iam looking for a system of up to 200hp for use with a single Dominator.Don't need a system w/expansion capabilities.Weight to hp will be close for index racing. I would like a few extra hp without changing the engine combo if needed to run the number. Just a good quality, no frills system. The price seems very reasonable. This car won't be raced often. Only Heads Up events and test and tune. Thanks,Bill
Re: Nitrous Express Mainline System [Re: lancer493] #3020500
03/03/22 01:49 PM
03/03/22 01:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I did the Mainline kit but it was for the 4150 carb. I wanted the basics and that's what this kit provides. We've used all the jetting from 100 to 250 and it's dead on! Very happy with it.
I would recommend something like the Leash electronics single stage board to compliment it. It makes wiring super easy and comes with relays, etc. Very reasonably priced as well.
'63 Dodge 330
11.19 @ 121 mph
Re: Nitrous Express Mainline System [Re: GY3] #3020577
03/03/22 07:02 PM
03/03/22 07:02 PM
St.Pete,Florida
St.Pete,Florida
GY3, thank you sir, I am glad to hear this. Frills cost money,. Sure sounds like this system is just what I am looking for. Anything more and I may just drive thru the convertor. Thank you again! Bill
Re: Nitrous Express Mainline System [Re: lancer493] #3020581
03/03/22 07:27 PM
03/03/22 07:27 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
A couple of extras you might want to add. We have a bottle heater powered by a DeWalt battery in the trunk. Mainly to just maintain pressure and not draw on the main battery.
Personally, I like using an infrared temp gun to monitor the bottle temp as I find it a little easier and more accurate than a gauge.
Coldfusion makes a budget bottle heater with a pressure switch that is adjustable.
You can really go down a rabbit hole buying accessories for nitrous. grin
'63 Dodge 330
11.19 @ 121 mph
Re: Nitrous Express Mainline System [Re: GY3] #3020603
03/03/22 09:16 PM
03/03/22 09:16 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If you are a Milwaukee M18 type of fellow PM me. We sell a base and everything you need for an automatic bottle heater. The transducer we use holds pressure within 25-50 psi.
For the controller I suggest the NOS mini progressive because it has a window switch, delay, and can monitor you bottle pressure through the handheld for about $200 extra.
The NOS mini progressive is just over $200.
Re: Nitrous Express Mainline System [Re: Jeremiah] #3020630
03/03/22 10:30 PM
03/03/22 10:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I should probably get a controller at some point rather than just hitting all of it off the line. grin
'63 Dodge 330
11.19 @ 121 mph
Re: Nitrous Express Mainline System [Re: GY3] #3020635
03/03/22 10:41 PM
03/03/22 10:41 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'd like leave on a 200 and ramp it to 300 eventually. Need mo tire and a Dana!
The window switch and bottle pressure read out seal the deal for me. It's a must have IMO.
What you need is a 4 speed!
Do you apray it off the line on an unprepped surface?
Re: Nitrous Express Mainline System [Re: Jeremiah] #3020654
03/04/22 12:57 AM
03/04/22 12:57 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I don't race any unprepped or "street" events anymore (a '63 Dodge isn't as plentiful and expendable as a Fox body) and rarely use nitrous on the street now with it on the 250 shot tune-up. We did do a hard tire race last year and I reduced the shot to 150 as I recall. Got out a little ways, got over eager and hit the button. Tires erupted and it was a pedal fest. Almost caught him at the line but lost by a bunper. LOL. The hard tire is like driving on ice with the torque this thing makes naturally aspirated.
I did some changes over the winter to get some more power n/a, but also eyeing a plate and solenoid change...
'63 Dodge 330
11.19 @ 121 mph
Re: Nitrous Express Mainline System [Re: GY3] #3020660
03/04/22 01:31 AM
03/04/22 01:31 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
As for index racing, we tried the 6.50 index a couple of years back after a friend talked us into it.
With a 200 shot the car ran a 6.52 earlier in the night. Figured close enough. This was before the bottle heater so I figured any temp change would be offset by bottle temp/pressure dropping a little. I left late and ran a 6.489. Ugh! Fastest the car had ever been with a 1.37 60 ft. footbraking, LOL! Lots of fun and learned a lot that night about what the car wanted.
We're the first pair in the video.
https://youtu.be/vbXjkCLaNz8
'63 Dodge 330
11.19 @ 121 mph
Re: Nitrous Express Mainline System [Re: GY3] #3020668
03/04/22 02:32 AM
03/04/22 02:32 AM
Nothing like being dead late tsk
You can do better up
Re: Nitrous Express Mainline System [Re: Cab_Burge] #3020682
03/04/22 08:10 AM
03/04/22 08:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, had a sandwich and a nap before I left. smile
'63 Dodge 330
11.19 @ 121 mph
Re: Nitrous Express Mainline System [Re: GY3] #3020736
03/04/22 11:13 AM
03/04/22 11:13 AM
St.Pete,Florida
St.Pete,Florida
Thanks for all the great replys on conservative yet efficient nitrous use here. All relevant information for me. I hope Dave takes a peek at all this info as the gains from a conservative nitrous system would far outweigh any cylinder head and/or cam change he could do. And for far less money to save for the hemi he wants. The key would be conservative nitrous to use existing parts, maybe adding valve notch modification or piston change out opening up options for bigger cams in the future. Looks like good dual carb systems can be had for in the $1300 range. much cheaper than any other option. But this is not my business,just my 2cents, as I am in a similar place where I know I may need a little more to run the number (not having a baseline yet), but I think I should have a fairly durable combo I put together for the possibility of adding "a little nitrous" if necessary. Thanks all again as I am really appreciative of this info. If I don't cap this combo here it will never get off the trailer! Bill
Re: Nitrous Express Mainline System [Re: lancer493] #3020745
03/04/22 11:33 AM
03/04/22 11:33 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I find it humorous that 200+ hp nitrous shot is considered conservative.
The jug is rowdy lol. Looking forward to seei g you meet your goals mr Bill!
Keep us in the loop with any updates.
Re: Nitrous Express Mainline System [Re: Jeremiah] #3020784
03/04/22 01:09 PM
03/04/22 01:09 PM
St.Pete,Florida
St.Pete,Florida
JD I truly meant 200 or less, starting at 100 if needed. Pistons and rings used had that in mind. Gotta get my feet wet yet. Has been a long time since I drove anything like this. I want to put some pictures on here when I figure out how to do it right. It's different. Bill
