340 Plymouth Arrow oil pan #3020451
03/03/22 11:29 AM
03/03/22 11:29 AM
Kentucky
Greencospeedshop Offline OP
Kentucky
Hello. Im building a 340 to put in a street car... a 78 Plymouth Arrow. I tried installing a 318 mock up motor to see what issues I'll run into and right away I see it looks like either a FRONT sump or maybe a mid sump (factory 340 style) will work.
Anybody done this? Any tips welcome.
I am considering taking a front sump oil pan from a dodge Dakota truck and splitting and slicing the two. Using the upper 2" from a stock 318 rear sump and grafting it to the front sump Dakota pan. If there is an easier and cheaper way id like to know. Thank you.
Officer to me...
"I had my pedal to the floor and you were still pulling away like a rocket!"
Re: 340 Plymouth Arrow oil pan [Re: Greencospeedshop] #3020462
03/03/22 11:55 AM
03/03/22 11:55 AM
md
mopars4ever Offline
mopars4ever  Offline
md
What was the 318 out of?
Re: 340 Plymouth Arrow oil pan [Re: mopars4ever] #3020484
03/03/22 01:04 PM
03/03/22 01:04 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Have a look at Kevco oil pans.
https://kevkoracing.com/collections/mopar
Re: 340 Plymouth Arrow oil pan [Re: 76Beeper] #3020650
03/04/22 12:41 AM
03/04/22 12:41 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The Sweptline trucks used a front sump pan.
Re: 340 Plymouth Arrow oil pan [Re: 76Beeper] #3020651
03/04/22 12:47 AM
03/04/22 12:47 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If the front sump Dakota pan is for a 318/5.2, it should bolt onto the 340. You will also want the pickup tube.
Re: 340 Plymouth Arrow oil pan [Re: Greencospeedshop] #3020686
03/04/22 08:43 AM
03/04/22 08:43 AM
E
earlymopar Offline
earlymopar  Offline
E
I have a Sweptline front sump pan if you're interested. If you're not sure on the shape you need, remove the pan on your mock up engine and get the block located where you want it. Then cut pieces of card board to mock up the sides of the pan and sump to come up with the pan shape you actually need.
Re: 340 Plymouth Arrow oil pan [Re: earlymopar] #3029679
04/01/22 05:36 PM
04/01/22 05:36 PM
S Williamsport
therick Offline
therick  Offline
S Williamsport
I used a factory car pan and this style of mounts
Re: 340 Plymouth Arrow oil pan [Re: therick] #3029793
04/01/22 10:14 PM
04/01/22 10:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I love that style of mount as the motor doesn't MOVE, they provide good isolation, and they are inexpensive. My only comment would be to add an additional crossmember between the two for added support of the additional weight if possible. Looking good
smile beer
Re: 340 Plymouth Arrow oil pan [Re: TJP] #3029977
04/02/22 02:15 PM
04/02/22 02:15 PM
moparx Offline
moparx  Offline
isn't that the "universal" early hemi style bracket that uses flathead ford rubber mounts ?
beer
Re: 340 Plymouth Arrow oil pan [Re: moparx] #3029984
04/02/22 02:31 PM
04/02/22 02:31 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Speedway Motors sells 32 Ford motor mounts that are a thru bolt design that are a way better choice than the ones that use plates of steel with studs attached and vulcanized rubber biscuits between two steel pieces. Studebaker used that weak style of mounts too, but many Stude owners opt for the 32 Ford style too.
Re: 340 Plymouth Arrow oil pan [Re: moparx] #3030099
04/02/22 09:44 PM
04/02/22 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
Don't know on the hemi part but yes on the Flathead biscuit mount wink
