Re: Pulley issues
[Re: ShawnS]
#3020344
03/02/22 09:38 PM
03/02/22 09:38 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
The ATI dampener maybe causing your issues, they make a bunch of different dampeners with different mounting surface depths for BB Mopars. What part number are you using?
Re: Pulley issues
[Re: ShawnS]
#3020497
03/03/22 01:43 PM
03/03/22 01:43 PM
Posts: 19,591 north of coder
moparx
i have "adjusted" the water pump pulley flange forward or rearward using a press. just watch your setup so you are not moving the impeller, or pressing on the case. not a hard job. if you don't have access to a press, however, well it's tough to do without one.
Re: Pulley issues
[Re: moparx]
#3020583
03/03/22 07:43 PM
03/03/22 07:43 PM
Posts: 610 Boise
Moparteacher
Boise
i have "adjusted" the water pump pulley flange forward or rearward using a press. just watch your setup so you are not moving the impeller, or pressing on the case. not a hard job. if you don't have access to a press, however, well it's tough to do without one. I have done the same except I removed the waterpump flange, machined it flat (parallel) and pressed it back on and parked it where I needed it. Beware, Chryler wp pulley uses a 5/8 pilot hole, Most pump shafts are 3/4" and stepped at the front of the flange so if you move the flange closer to the housing you may expose the 3/4' shaft and have to accompodate by enlarging the pulley pilot hole. AndyF makes the crank spacers, others make the wp spacers.
Re: Pulley issues
[Re: Moparteacher]
#3020602
03/03/22 09:12 PM
03/03/22 09:12 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Looks like you have a spacer between the crank pulley and dampener, no?
Also water pump gaskets are of varying thickness.
Re: Pulley issues
[Re: ShawnS]
#3020794
03/04/22 01:40 PM
03/04/22 01:40 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Normally I'd send someone to Bouchillon for that kind of a situation, but they don't sell anything specifically for an ATI damper or aluminum water pump housing/both change things a little.
I think you're going to end up with spacers unless you want to start over with a few different parts.
Rich H.
Esse Quam Videri
