Muffler Ideas for 505. #3019186
02/26/22 07:50 PM
02/26/22 07:50 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Anyone have exhaust building experience with a setup like I have here? It's a 505 for my Ramcharger, the headers are 2" primary mad dogs, with 3.5" collectors. I need to come up with a muffler that won't smother the engine but also isn't crazy loud since the truck will be on 37's, so the exhaust will be at car window height.
Engine: 505, trickflow 270s, 550 ish cam hydraulic roller, indy dual plane, 10:1, 950 cfm carb.
I have total length of 48" to fit it all into, and on the outside of the frame I have about 10" between the parking brake brackets and the middle of the rocker panel.
Should I neck it down to 3" and the go with the longest round muffler I can find, or go with a 20" normal round and put a spiral silencer in the middle? Ideas?
Re: Muffler Ideas for 505. [Re: Uberpube] #3019253
02/26/22 11:24 PM
02/26/22 11:24 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run 3 1/2" collector neck to 3" then use Hooker Aerochambers in front of diff.
505 , tf270 heads , Dougs headers
Works for me not excessively loud at lower street rpm, ok wide open .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Muffler Ideas for 505. [Re: tex013] #3019290
02/27/22 02:01 AM
02/27/22 02:01 AM
New York, USA
Chargerfan68 Offline
New York, USA
I have 2 cars, both with 505”. Close in power. One dynoed at hair over 600 hp and maybe the other 650-660 hp based on track/ weight /et-mph comparisons with eachother. Both just about 10.4 and 10.6:1.
1 has 2” hookers into 3” ex and x pipe using Dynomax Ultraflo 3” mufflers. Sounds good.
The other 1-7/8” hooker headers into 2-1/2” ex with x pipe and into Magnaflow stainless welded mufflers. Both dumped at axles. The Magnaflow system, even though smaller and slightly less power, sounds better to me. Just has a nicer sound to me. Both perform very well in car.
At track, the Magnaflow system lost .15 et and 1 mph in back to back testing same day within an hour of eachother.
Re: Muffler Ideas for 505. [Re: Chargerfan68] #3019309
02/27/22 07:09 AM
02/27/22 07:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would run a Dynomax Ultaflow and possibly run a glasspack in front of it.
68 Barracuda Formula S 340
Re: Muffler Ideas for 505. [Re: Uberpube] #3019326
02/27/22 10:29 AM
02/27/22 10:29 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I’m at the exact same point. I purchased the Mad Dogs for my 77 w150 that has a 528. I haven’t build a street vehicle for years so I’m clueless on muffler options to keep this thing quite. Do you have standard cab and short box? Hopefully I’ll have a little more length to work with as my truck is a Club cab. Didn’t you have header clearance issues with the shocks? How did you fix that? Sorry to rob the post.
Re: Muffler Ideas for 505. [Re: sjs64polara] #3019334
02/27/22 11:01 AM
02/27/22 11:01 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Pypes racepro. Fairly quiet until you stand on the loud peddle.
America First!
Re: Muffler Ideas for 505. [Re: sjs64polara] #3019335
02/27/22 11:02 AM
02/27/22 11:02 AM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
The quietest straight through muffler I've found is Pypes race pro. Much quieter than Magnaflow and Ultra Flow.
Edit-carnut beat me to it, agreed smile
Re: Muffler Ideas for 505. [Re: INTMD8] #3019369
02/27/22 12:23 PM
02/27/22 12:23 PM
moparx Offline
moparx  Offline
i have heard the auger/spiral inserts don't do much but make your wallet lighter.
i read a test about those years ago, but i can't remember where.
perhaps others can chime in with real world info on that style of insert ?
beer
Re: Muffler Ideas for 505. [Re: Uberpube] #3019391
02/27/22 01:05 PM
02/27/22 01:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
On (2) W150 I did 2.5" exhaust pipes. Passenger Side pretty much straight back with a slight offset around the transfer case. The Drivers side went back and crossed over to the passenger side behind the transfer case then ran parallel to the other exhaust tube. one had dual turbo mufflers side by side, the other used a dual 2.5" inlet, single 3" out baffled muffler. I don't recall the muffler brand, it was a smaller brand name, and it may have actually been a 3" in, dual 2.5 out installed backwards? I sounded good with a warmed over 318?
Because these were the trucks with drivers side fuel tank, the muffler(s) were on the passenger side. The '84 RamCharger had the rear mounted 35 gallon fuel tank, so I think there is room for a muffler on the drivers side?
If you are using that rear mounted fuel tank, I would modify it to limit fuel slosh (Fuel cell foam or baffles.)
I had about 20 gallons of fuel in my tank, and took a corner a bit to fast, and the fuel slosh kicked the back end loose, then when I went to correct, it sloshed the other direction and spun the 95" WB truck around. Rear tire caught a curb and tipped the Ramcharger over onto the side.
I think the Muffler Brand used for the dual inlet single exit was IMCO? When I looked it up, it seems to be Cherry Bomb?
Re: Muffler Ideas for 505. [Re: 451Mopar] #3019481
02/27/22 06:49 PM
02/27/22 06:49 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
It's a Ramcharger, so half foot shorter than a short box. There is no goo way of going back inside the frame so everything will be on the outside.
I read the reviews on the Pypes bullet mufflers and it seems they muffle better one would expect.i'm thinking of starting with those and then if its too raunchy, adding a short spiral to the end before a down turned tip. I'll go 3.5 off the collector through the bends to 3" at the muffler.
Re: Muffler Ideas for 505. [Re: Uberpube] #3019486
02/27/22 07:18 PM
02/27/22 07:18 PM
gregsdart Offline
gregsdart  Offline
Can you add a cross over tube? Said to be worth it for both noise and power. Next would be a call to Walker? They may have some great info.
Re: Muffler Ideas for 505. [Re: gregsdart] #3038619
04/30/22 09:49 PM
04/30/22 09:49 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
So this is what I ended up doing. Took me a little while to get back into tig welding, haven't done anything for like 6 months. System is 3.5" all stainless with dynomax mufflers.
Re: Muffler Ideas for 505. [Re: Uberpube] #3038621
04/30/22 09:51 PM
04/30/22 09:51 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
fitting and more fitting.
Re: Muffler Ideas for 505. [Re: Uberpube] #3038622
04/30/22 09:52 PM
04/30/22 09:52 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Made the tailpipe downturns, Welding it all up tomorrow.
Re: Muffler Ideas for 505. [Re: Uberpube] #3038693
05/01/22 08:29 AM
05/01/22 08:29 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
They are nice well built mufflers and not too expensive. I have the oval ones. I have been running them for about 8 yrs along with a couple friends.
America First!
Re: Muffler Ideas for 505. [Re: carnut68] #3038703
05/01/22 09:00 AM
05/01/22 09:00 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I like the Kooks polished stainless mufflers. Best looking and sounding muffs I have ever had on any of my street strip cars. They are at home at both places.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Muffler Ideas for 505. [Re: B3422W5] #3038707
05/01/22 09:37 AM
05/01/22 09:37 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
When it came down to it, the dynomax mufflers were the only thing in stock when I ordered. Even getting the 3.5" pipe was tough, most places were 4-6 weeks backordered. I got my hands on a length of pipe and it was made in Taiwan, had to wait for a second length, same brand of pipe and it was surprisingly made in Canada. Maybe the supply chain is starting to come home now.
Re: Muffler Ideas for 505. [Re: Uberpube] #3038721
05/01/22 10:24 AM
05/01/22 10:24 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
You can buy 3.5 in pipe at most heavy truck part places.
America First!
Re: Muffler Ideas for 505. [Re: carnut68] #3038730
05/01/22 10:56 AM
05/01/22 10:56 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I tried that, the straight pieces they had were Aluminized steel, and their stainless went straight jump from 3" to 4" with no half sizes. It was fun walking in around in their store though.
Re: Muffler Ideas for 505. [Re: Uberpube] #3038833
05/01/22 05:49 PM
05/01/22 05:49 PM
IL
furious70 Offline
furious70  Offline
IL
Nice slices of pie! up
70 Sport Fury
68 Charger
69 Coronet
72 RR
