Muffler Ideas for 505.
#3019186
02/26/22 07:50 PM
02/26/22 07:50 PM
Posts: 708 Southern Alberta
Uberpube
Southern Alberta
Anyone have exhaust building experience with a setup like I have here? It's a 505 for my Ramcharger, the headers are 2" primary mad dogs, with 3.5" collectors. I need to come up with a muffler that won't smother the engine but also isn't crazy loud since the truck will be on 37's, so the exhaust will be at car window height. Engine: 505, trickflow 270s, 550 ish cam hydraulic roller, indy dual plane, 10:1, 950 cfm carb. I have total length of 48" to fit it all into, and on the outside of the frame I have about 10" between the parking brake brackets and the middle of the rocker panel. Should I neck it down to 3" and the go with the longest round muffler I can find, or go with a 20" normal round and put a spiral silencer in the middle? Ideas?
Re: Muffler Ideas for 505.
[Re: Uberpube]
#3019253
02/26/22 11:24 PM
02/26/22 11:24 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I run 3 1/2" collector neck to 3" then use Hooker Aerochambers in front of diff. 505 , tf270 heads , Dougs headers Works for me not excessively loud at lower street rpm, ok wide open .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3019290
02/27/22 02:01 AM
02/27/22 02:01 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have 2 cars, both with 505”. Close in power. One dynoed at hair over 600 hp and maybe the other 650-660 hp based on track/ weight /et-mph comparisons with eachother. Both just about 10.4 and 10.6:1.
1 has 2” hookers into 3” ex and x pipe using Dynomax Ultraflo 3” mufflers. Sounds good. The other 1-7/8” hooker headers into 2-1/2” ex with x pipe and into Magnaflow stainless welded mufflers. Both dumped at axles. The Magnaflow system, even though smaller and slightly less power, sounds better to me. Just has a nicer sound to me. Both perform very well in car.
At track, the Magnaflow system lost .15 et and 1 mph in back to back testing same day within an hour of eachother.
[Re: Chargerfan68]
#3019309
02/27/22 07:09 AM
02/27/22 07:09 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I would run a Dynomax Ultaflow and possibly run a glasspack in front of it.
68 Barracuda Formula S 340
[Re: Uberpube]
#3019326
02/27/22 10:29 AM
02/27/22 10:29 AM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
I’m at the exact same point. I purchased the Mad Dogs for my 77 w150 that has a 528. I haven’t build a street vehicle for years so I’m clueless on muffler options to keep this thing quite. Do you have standard cab and short box? Hopefully I’ll have a little more length to work with as my truck is a Club cab. Didn’t you have header clearance issues with the shocks? How did you fix that? Sorry to rob the post.
[Re: sjs64polara]
#3019334
02/27/22 11:01 AM
02/27/22 11:01 AM
Posts: 3,193 Md.
carnut68
Md.
Pypes racepro. Fairly quiet until you stand on the loud peddle.
America First!
[Re: sjs64polara]
#3019335
02/27/22 11:02 AM
02/27/22 11:02 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
The quietest straight through muffler I've found is Pypes race pro. Much quieter than Magnaflow and Ultra Flow. Edit-carnut beat me to it, agreed
[Re: INTMD8]
#3019369
02/27/22 12:23 PM
02/27/22 12:23 PM
Posts: 19,431 north of coder
moparx
i have heard the auger/spiral inserts don't do much but make your wallet lighter. i read a test about those years ago, but i can't remember where. perhaps others can chime in with real world info on that style of insert ?
[Re: Uberpube]
#3019391
02/27/22 01:05 PM
02/27/22 01:05 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
On (2) W150 I did 2.5" exhaust pipes. Passenger Side pretty much straight back with a slight offset around the transfer case. The Drivers side went back and crossed over to the passenger side behind the transfer case then ran parallel to the other exhaust tube. one had dual turbo mufflers side by side, the other used a dual 2.5" inlet, single 3" out baffled muffler. I don't recall the muffler brand, it was a smaller brand name, and it may have actually been a 3" in, dual 2.5 out installed backwards? I sounded good with a warmed over 318? Because these were the trucks with drivers side fuel tank, the muffler(s) were on the passenger side. The '84 RamCharger had the rear mounted 35 gallon fuel tank, so I think there is room for a muffler on the drivers side? If you are using that rear mounted fuel tank, I would modify it to limit fuel slosh (Fuel cell foam or baffles.) I had about 20 gallons of fuel in my tank, and took a corner a bit to fast, and the fuel slosh kicked the back end loose, then when I went to correct, it sloshed the other direction and spun the 95" WB truck around. Rear tire caught a curb and tipped the Ramcharger over onto the side.
I think the Muffler Brand used for the dual inlet single exit was IMCO? When I looked it up, it seems to be Cherry Bomb?
[Re: Uberpube]
#3038693
05/01/22 08:29 AM
05/01/22 08:29 AM
Posts: 3,193 Md.
carnut68
Md.
It's a Ramcharger, so half foot shorter than a short box. There is no goo way of going back inside the frame so everything will be on the outside. I read the reviews on the Pypes bullet mufflers and it seems they muffle better one would expect.i'm thinking of starting with those and then if its too raunchy, adding a short spiral to the end before a down turned tip. I'll go 3.5 off the collector through the bends to 3" at the muffler. They are nice well built mufflers and not too expensive. I have the oval ones. I have been running them for about 8 yrs along with a couple friends.
America First!
[Re: carnut68]
#3038703
05/01/22 09:00 AM
05/01/22 09:00 AM
Posts: 11,714 Portage,michigan
B3422W5
Portage,michigan
I like the Kooks polished stainless mufflers. Best looking and sounding muffs I have ever had on any of my street strip cars. They are at home at both places.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Uberpube]
#3038721
05/01/22 10:24 AM
05/01/22 10:24 AM
Posts: 3,193 Md.
carnut68
Md.
When it came down to it, the dynomax mufflers were the only thing in stock when I ordered. Even getting the 3.5" pipe was tough, most places were 4-6 weeks backordered. I got my hands on a length of pipe and it was made in Taiwan, had to wait for a second length, same brand of pipe and it was surprisingly made in Canada. Maybe the supply chain is starting to come home now. You can buy 3.5 in pipe at most heavy truck part places.
America First!
[Re: carnut68]
#3038730
05/01/22 10:56 AM
05/01/22 10:56 AM
Uberpube
Southern Alberta
When it came down to it, the dynomax mufflers were the only thing in stock when I ordered. Even getting the 3.5" pipe was tough, most places were 4-6 weeks backordered. I got my hands on a length of pipe and it was made in Taiwan, had to wait for a second length, same brand of pipe and it was surprisingly made in Canada. Maybe the supply chain is starting to come home now. You can buy 3.5 in pipe at most heavy truck part places. I tried that, the straight pieces they had were Aluminized steel, and their stainless went straight jump from 3" to 4" with no half sizes. It was fun walking in around in their store though.
[Re: Uberpube]
#3038833
05/01/22 05:49 PM
05/01/22 05:49 PM
Posts: 2,255 IL
furious70
IL
So this is what I ended up doing. Took me a little while to get back into tig welding, haven't done anything for like 6 months. System is 3.5" all stainless with dynomax mufflers. Nice slices of pie!
70 Sport Fury 68 Charger 69 Coronet 72 RR
