Aftermarket Guage Question?
#301903
04/28/09 10:51 AM
04/28/09 10:51 AM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
I have an Autometer fuel guage and matching sender combo.
I wired it up, and then with some help wires got moved etc. during a build. I am sure there was a spark or two if you catch my drift.
It did work initially.
Now it does not.
I am thinking I need a new guage. It has a good ground and a switched power etc.
Guage or sender? Which is most likely screwed up?
Thank you for any help.
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: Aftermarket Guage Question?
[Re: toyotajeep]
#301904
04/28/09 05:35 PM
04/28/09 05:35 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
just a thought but the gauges measure resistance. Get a resistor from radioshack that works in the range of your gauge. use that to see if your gauge is reading. This will allow you to narrow down if the sending unit is sending the right information to the guage or not.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: toyotajeep]
#301905
04/28/09 05:59 PM
04/28/09 05:59 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Depends if you want to diagnose the problem and replace or repair the bad item or searching for a quick answer.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#301907
04/28/09 06:08 PM
04/28/09 06:08 PM
Also, I'm not familiar with Autometer, but some electric gauges are what is known as a "bridge" circuit, as in, Wheatstone Bridge. What this means is that the third leg of the circuit is the gauge FRAME which must be grounded
#301908
04/28/09 06:12 PM
04/28/09 06:12 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Most all autometer are three wire
Ground positive and sender lead.
Allen
#301909
04/28/09 06:13 PM
04/28/09 06:13 PM
Posts: 7,759 So Cal
HealthServices
So Cal
http://www.autometer.com/productPDF/1079A.pdfMake sure everything is connected correctly before replacing things
Allen
#301910
04/28/09 06:15 PM
04/28/09 06:15 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If you have a ohm meter you can bench test the sending unit too.
Allen
