Re: Changing steering boxes.
[Re: BlueRacer69]
#3017760
02/22/22 03:39 PM
02/22/22 03:39 PM
Posts: 21,830 Kirkland, Washington
Pacnorthcuda
Why do I need arm muscle when I have a impact wench. So I'm guessing no other components need to be changed except the steering box, correct? They are talking about increased STEERING effort with the faster ratio.
[Re: BlueRacer69]
#3017801
02/22/22 06:41 PM
02/22/22 06:41 PM
Posts: 31,046 Oregon
AndyF
Hi fellow members. I'm thinking of changing my 1969 big block Dart steering box from the factory 24:1 ratio to the faster 16:1 ratio. If I do, are there any other components that need changing along with it? Thanks. You don't want a 16:1 ratio box in a big block car. Even a 20:1 box is hard to steer at slow speeds. A 16:1 box is brutal in a parking lot or parallel parking.
[Re: AndyF]
#3017886
02/22/22 10:49 PM
02/22/22 10:49 PM
Posts: 732 Michigan
BlueRacer69
Hi fellow members. I'm thinking of changing my 1969 big block Dart steering box from the factory 24:1 ratio to the faster 16:1 ratio. If I do, are there any other components that need changing along with it? Thanks. You don't want a 16:1 ratio box in a big block car. Even a 20:1 box is hard to steer at slow speeds. A 16:1 box is brutal in a parking lot or parallel parking. Okay. Maybe I have the steering boxes mixed up then. I was thinking the factory's 16:1 manual box was an option on Dodge cars back in the day and was suppose to be easier to steer. Maybe it's the other way around and I want the 24:1 box. What ratio manual steering boxes came standard on Dodge cars back in 1969?
[Re: AndyF]
#3018774
02/25/22 11:02 AM
02/25/22 11:02 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The fast ratio box was used in the T/A and AAR E bodies , but it used a longer pitarm , maybe a longer idler arm also ? I never drove one , only a big block A body with manual steering and once you got moving it wasn't bad .
[Re: Cab_Burge]
#3019280
02/27/22 12:35 AM
02/27/22 12:35 AM
Posts: 259 n.c.
geo.
n.c.
The fast ratio box was used in the T/A and AAR E bodies , but it used a longer pitarm , maybe a longer idler arm also ? I never drove one , only a big block A body with manual steering and once you got moving it wasn't bad . All the T/A and AAR Cuda came with power steering is what I was told by Galen when I had my T/A Nope! Personally seen a stock T/A with the 24-1 manual box. Heard about a T/A equipped with regular power steering since new. I'd assume both types of power were options on a T/A, unless this was an assembly line screw-up. I'd vote for a 20-1 box in an A body if going manual. But NEVER on a car you might want to autocross with!
[Re: geo.]
#3019308
02/27/22 07:04 AM
02/27/22 07:04 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Article in mopar action years ago mentioned a ta not having the quick ratio as being a deal breaker, so the guy went around and tried others until he found one.
I want my fair share
[Re: Cab_Burge]
#3019419
02/27/22 01:56 PM
02/27/22 01:56 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
All the T/A and AAR Cuda came with power steering is what I was told by Galen when I had my T/A If he did say that, he was wrong. The T/As came with manual steering standard & regular power steering as well as fast ratio power steering were extra cost items. For the AARs, standard with manual steering also, but the only extra cost option was fast ratio power steering. (no regular power steering in an AAR)
[Re: BlueRacer69]
#3019565
02/28/22 12:52 AM
02/28/22 12:52 AM
Posts: 21,648 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Thanks for the advice guys. I guess I'll stick with a new 24:1 ratio steering box from PST. To be honest, I really do like the Firm Feel Inc stage Ii power steering box. The feel of it and the way it works compared to stock on is totally different. Dick (one of the owners) builds and races only Mopar suspension. If you want to handle great as well as steer great, get in contact with him and he’ll give you nicest guys with the nicest stuff.
