Re: Raised exhaust port hemi in a b body.
[Re: crowbait]
#3012775
02/06/22 04:19 PM
02/06/22 04:19 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Raised ports for 600hp?
Sounds like a completely avoidable headache to me.
[Re: crowbait]
#3012931
02/07/22 12:10 AM
02/07/22 12:10 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
for that hp range do standard port. you would need custom headers for raised port.
JAKES AUTOMOTIVE
[Re: JAKE68]
#3013013
02/07/22 12:49 PM
02/07/22 12:49 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Standard port will be fine for that cubic inch and horse power range. I am making alot more than that with Standard port Heads still with a 10.5:1 pump gas street engine. However, mine is 528".
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3013038
02/07/22 02:16 PM
02/07/22 02:16 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Nobody cares that I agree, but Stock replacement type heads is all that's needed.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3013042
02/07/22 02:22 PM
02/07/22 02:22 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Nobody cares that I agree, but Stock replacement type heads is all that's needed. I care LOL
[Re: crowbait]
#3013110
02/07/22 05:05 PM
02/07/22 05:05 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
What are the draw backs, if any to the exhaust raised port location in a b/e body stock engine location/stock suspension situation? My goal is 600 horse 426 cu inch street build. To that end I have Hooker slip together headers, mild solid lift crane cam, Milodon gear drive, Indy single 4 intake, 850 Holley. I need to buy heads next, so here I am looking for advice. As stated above, any head will fit your needs. That being said, the best bang for the buck is still the Edelbrocks. The price has gone up but any head will end up costing as much by the time you get them done. I haven't heard of the raised ports causing an interference problem for anybody. The only minor thing you have to do is use a sanding roll to clearance the top of the cylinder for the large intake valve because you are 4.25" bore. Easy-peasy. What this will give you is brand new aluminum heads and the best high flowing ports. There's no way I'm going to pay the same money and not get brand new, latest tech, good stuff.
2011 Drag Pak Challenger
[Re: rickseeman]
#3013152
02/07/22 07:49 PM
02/07/22 07:49 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
^ I just wonder if Edelbrocks are a good match for stock displacement, if what I'm reading is correct, 245cc intake runners out of the box.
My iron heads after porting measured 196cc intake port. I'm running a decent sized cam and it's peaking at 7250rpm and not falling off by 7600.
[Re: 6PKRTSE]
#3013292
02/08/22 09:32 AM
02/08/22 09:32 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
[s][/s] Standard port will be fine for that cubic inch and horse power range. I am making alot more than that with Standard port Heads still with a 10.5:1 pump gas street engine. However, mine is 528". I have the old style Mopar Performance aluminum heads (std port location) on my 11:1 pump gas 572" hemi. Basically aluminum versions of the stock iron heads. Had MCH cnc port them and makes somewhere in the 850 hp ballpark naturally aspirated.
[Re: crowbait]
#3013339
02/08/22 01:34 PM
02/08/22 01:34 PM
rickseeman
Stuttgart, Arkansas
100% agree on the Edelbrock bang for the buck. What about the tipped valve angle head vs the standard valve angle piston relief? Is collision likely? I agree the port volume is probably a touch high. I wouldn't think that would be an issue with the cam he will be running.
[Re: crowbait]
#3013351
02/08/22 01:56 PM
02/08/22 01:56 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
What are the draw backs, if any to the exhaust raised port location in a b/e body stock engine location/stock suspension situation? My goal is 600 horse 426 cu inch street build. To that end I have Hooker slip together headers, mild solid lift crane cam, Milodon gear drive, Indy single 4 intake, 850 Holley. I need to buy heads next,so here I am looking for advice.
Thanks Guys! Other than the headers needing to match the heads there is no other fit issues that I know of going with a raised port head. Please chime in if you know different.
[Re: moparx]
#3013573
02/08/22 11:33 PM
02/08/22 11:33 PM
Posts: 1,093 Brookville Pa
crowbait
Brookville Pa
crowbait has so many projects going, i forget what he has parts wise, for each. It keeps me young! No heads yet,but I do have new stands and shafts with used rockers arms Cam is a crane 661201 solid flat tappet .238/.248@.050 112deg LSA .502/.507 lift with the correct springs Header is 2 1/8" dia with 3 1/2" collector stock port location
