Re: What is a good tire/size for a Ramcharger?
[Re: migsBIG]
#3012000
02/03/22 07:45 PM
02/03/22 07:45 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Thanks for the info everyone. The truck originally cam with 28’s and I believe the ratios were 3:55 so it would be good with taller rubber. It looks good but I have though about upping the hight a couple/three inches to make the rubber a bit more bigger. Not sure as what I finally want, this why I’m here asking questions. Stuff could still change. Will see what options I have when the time comes. IIRC, 4x4's came with 31x10.5's? (30.5) edit: optional on 4x4, no spare tire cover 2wd P235/75R15 (29"). P275/60R15 (28") is what I usually ran on my '82 2wd Ramcharger. That was the widest for that truck, axle wasn't quite centered, rubbed the drivers side wheel house very slightly, kept it cleaned off.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: migsBIG]
#3012372
02/05/22 07:44 AM
02/05/22 07:44 AM
Posts: 5,854 ohio
ruderunner
ohio
31s fit without lift and play well with the existing drivetrain. Bigger tires are going to want lift and gears.
As unmolested as this truck appears, I'd keep things stock.
Angry white pureblood male
[Re: MuscleMopars]
#3012396
02/05/22 10:20 AM
02/05/22 10:20 AM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
LT285/75r17 - Same as a 33 but a little over 9" of tread width.....I'm a HUGE fan of these Cooper Discoverer AT3 XLT
I put those tires (same size and everything) on both my wife's trucks, her 74 Ramcharger and her FJ Cruiser
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
