Radiator cores #3010929
01/31/22 07:34 PM
01/31/22 07:34 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Every available 26" radiator for my 1973 Charger 340 CID has the over flow nipple pointing the wrong way towards the drivers side. It should point to the passenger side on a 1973 model year.
where can I purchase just a core?
Thanx for the help.
Re: Radiator cores [Re: Gabmando] #3010932
01/31/22 07:54 PM
01/31/22 07:54 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Are you looking for a shop to re-core your radiator, reusing the existing tank/neck/nipple?
Or do you want to buy the bulk material to re-core the radiator yourself?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Radiator cores [Re: DynoDave] #3010945
01/31/22 09:15 PM
01/31/22 09:15 PM
Thomaston, CT
Frankie P Offline
Frankie P  Offline
Thomaston, CT
Who do you use Dyno?
70 Charger R/T 440 4spd Dana
Re: Radiator cores [Re: Gabmando] #3010950
01/31/22 09:34 PM
01/31/22 09:34 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanx for the help.
Why not just have the cap neck turned? I'm sure there are many local radiator shops that can do just that. Or contact Bob........@ Glen-ray http://www.restorationradiators.com/
Re: Radiator cores [Re: Gabmando] #3010984
01/31/22 10:53 PM
01/31/22 10:53 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Call Glen Ray radiators, they will take care of you.
Re: Radiator cores [Re: 71birdJ68] #3011006
02/01/22 12:17 AM
02/01/22 12:17 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
if you want to spend 1000 plus
5549 post on old board
Re: Radiator cores [Re: A12] #3011009
02/01/22 12:35 AM
02/01/22 12:35 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
Why not just have the cap neck turned? I'm there are many local radiator shops that can do just that.
penguin
Re: Radiator cores [Re: 05dakota] #3011375
02/01/22 10:55 PM
02/01/22 10:55 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Yes but they work, especially the 22 inch big block b body ones. After the hell i went through 4000 woul d have been cheap beer
Re: Radiator cores [Re: TJP] #3011598
02/02/22 03:38 PM
02/02/22 03:38 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree Glen Ray and sometimes no grief and done right is worth the money
Facts are stubborn things.
Re: Radiator cores [Re: A12] #3011713
02/02/22 09:23 PM
02/02/22 09:23 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Thanx for the help.
there are no local radiator shops any more...Or they are VERY few and far between
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Radiator cores [Re: yella71] #3011725
02/02/22 09:58 PM
02/02/22 09:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Where are you looking to purchase a radiator from? Could you pay extra to have them turn the fill neck? I am assuming you are looking for a replacement brass/copper radiator since you are concerned about the position of the overflow outlet, so your choices are probably pretty limited.
That said, I know the Champion aluminum radiator main outlet will modify one of their existing radiators to fit your needs. I've also seen a few racing radiator outlets that will build the radiator you need, but you have to get the radiator from the people that build them, not one of the retail outlets.
Re: Radiator cores [Re: poorboy] #3011732
02/02/22 10:44 PM
02/02/22 10:44 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I still use Ring Radiators in Antioch, Illinois and they may be the last one in my neck of the woods, thank goodness they are still around... up
JB Rhinehart, Realist
A-Body's RULE!
Re: Radiator cores [Re: yella71] #3011733
02/02/22 10:45 PM
02/02/22 10:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanx for the help.
yella71 are you in the same area as the OP? I know in the Cleveland, Ohio area there's still a few, one in particular that re-cored my '68 RR not that long ago. Just googled the place and still offering the same services. OP should do a search for radiator repair and re-core services in his area. Or just get out the torch and try himself if he's planning on replacing it anyway ozbbq grin
Re: Radiator cores [Re: Gabmando] #3011744
02/02/22 11:05 PM
02/02/22 11:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanx for the help.
I'm sure you know that the overflow nipple has nothing to do with the sealing of the radiator or radiator cap. If it's only a concern of the direction it is pointing I would remove that nipple and drill and place the nipple in the OE direction it needs to be, and plug the hole with silver solder or brass and be done with it, Just saying, Oh and I did a search in the Twin Cities area and found a couple or custom radiator repair and re-coring place there.
Re: Radiator cores [Re: A12] #3011995
02/03/22 07:31 PM
02/03/22 07:31 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you for all the responses. Let me explain why I'm asking for a source to buy cores:
1- As mentioned, there are very few radiator shops around any more. I called one local shop and was quoted $850 for a re-core.
2- I called another local shop, and they were interested in working on large commercial units.
3- I called Glen Ray over a year ago and left them a voice mail. i asked if I could send in my tanks and brackets for a re-core. I never got a call back. No I'm not interested in paying $1000.
4- I talked to classic industries regarding the published information on small block radiators. I sent pictures showing that the nipple points to the passenger side on 73 and 74 cars. That is where the overflow tank is located.
The person i talked to sent an email to Mark Worman asking for his input and copied me. Mark Worman never responded.
5- Yes I can buy a radiator from classic industries and go through the effort of having the filler neck indexed correctly. That is a radiator that does not show correct part numbers, and has an additional hole that needs to be plugged.
Having said all that, it makes sense to me to try and purchase a core if possible and swap out the tanks. I've rodded out a few radiators over the years. It's not that difficult.
What I did not mention is that I have another radiator that also needs to be re-cored. It's for the 1970 Challenger SE big block I'm restoring. I'd like to keep the original tanks.
It appears from what I'm seeing that buying cores is not going to be option. Next thing I'll have to try is widening my search radius and going an hour or more out of this metro area.
Thanx again for everyone's input and help.
If anyone form Minnesota can recommend a radiator shop that they've dealt with I'd really appreciate it.
Re: Radiator cores [Re: Gabmando] #3012011
02/03/22 08:30 PM
02/03/22 08:30 PM
A727Tflite Offline
A727Tflite  Offline
Price out the shipping to/from Troy Michigan. I just had my original rad for my 71 Hemi GTX recored.
$450.
PM me is you want the exact address along with the companies name. Guy has been doing this work since 1959.
Re: Radiator cores [Re: A727Tflite] #3012026
02/03/22 09:26 PM
02/03/22 09:26 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Transman yes please do share the contact information of the radiator shop.
Re: Radiator cores [Re: Gabmando] #3012039
02/03/22 10:39 PM
02/03/22 10:39 PM
A727Tflite Offline
A727Tflite  Offline
PM sent.
Re: Radiator cores [Re: A727Tflite] #3012077
02/04/22 04:00 AM
02/04/22 04:00 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think Spectra Premium makes cores or at least they used to.
Kevin
Re: Radiator cores [Re: A727Tflite] #3013711
02/09/22 01:41 PM
02/09/22 01:41 PM
PA
moparacer Offline
moparacer  Offline
PA
Quote
$450.
$450 for a Hemi rad? That is 1995 prices right there..... The proper core with tube size and fin count would cost me more than that. You got a deal if it is the right spec core.
Been doing rads for 33 years and I would gladly swap a neck for you but its a bit too far to drive.... hammer
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
