Re: What's broke in my trans?
[Re: mercman1]
#3010651
01/30/22 08:07 PM
01/30/22 08:07 PM
Posts: 667 IL
Dart451
IL
Bellview spring Littel more info Has same ting happen few years ago
[Re: mercman1]
#3010656
01/30/22 08:20 PM
01/30/22 08:20 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
What color is the fluid? If it's brown and smells, you lost the forward clutch pack.. If it's red, time to pull the pan to see what's in it.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3010701
01/30/22 11:33 PM
01/30/22 11:33 PM
Posts: 11,558 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Forward clutch. (rear clutch). The drum with the input shaft sticking out of it. Take it apart.
I'm assuming manual VB. If not, look at the roller clutch as well.
NVM, just saw automatic. Manual low should apply the rear band. No go in manual low, forward clutch. Either way, it's coming out.
[Re: CMcAllister]
#3010748
01/31/22 10:00 AM
01/31/22 10:00 AM
Posts: 876 Missouri
jwb123
Missouri
NVM, just saw automatic. Manual low should apply the rear band. No go in manual low, forward clutch. Either way, it's coming out. YEP it lost the forward clutch, forward clutch is applied in all the forward gears so it takes a lot of abuse. Direct clutch is applied with the low band for reverse. If you do the work yourself, make sure the sealing rings and grooves on the stator support are in good shape, high RPM and just a little bushing clearance will damage them, causing an internal pressure leak, taking out the forward clutch.
[Re: jwb123]
#3010761
01/31/22 10:30 AM
01/31/22 10:30 AM
Posts: 9,835 MI, usa
dvw
MI, usa
Could also be a stripped front planet on the output shaft. Been there. Doug
