Cheap dependable commuter car. #3008338
01/23/22 09:37 PM
01/23/22 09:37 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
My coworker is looking for a cheap dependable commuter car.
He needs something that is easy to work on, 4 cylinder, fwd, cheap to repair.
The Honda Civic looks like a good candidate.
Anyone have any other suggestions/experience?
Anything to stay away from?
Re: Cheap dependable commuter car. [Re: 1970GTX] #3008341
01/23/22 09:42 PM
01/23/22 09:42 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Everyone I've spoken to that had a Dart liked it. If you can find an unthrashed Focus or Cruze, you can probably get it cheaper than a comparable Civic or Corolla. My younger daughter just turned 14, and the cars I mentioned are the ones I will be looking to get for her. Market has changed, but 2.5 years ago, I picked up an 06 Civic with 96k on it for my older daughter. Car has been flawless, has 124k on it now. I've done brakes, tires, belts, hoses, fluids, and rear stabilizer links and bushings. I've got about $5k in it, including purchase price.
Avoid anything European. My $.02.
Earning every penny of that moderator paycheck.
DBAP
Re: Cheap dependable commuter car. [Re: 1970GTX] #3008342
01/23/22 09:44 PM
01/23/22 09:44 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
My little brother really likes his Honda Insight, 52 MPG?. He's a recent convert from Nissan. Don't know anything about repair costs, he hasn't had any.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Cheap dependable commuter car. [Re: 1970GTX] #3008356
01/23/22 10:03 PM
01/23/22 10:03 PM
AndyF Offline
AndyF  Offline
I bought a used Nissan Leaf electric car on the dealer lot for $7500. Had a little over 20,000 miles and was still under warranty. That has been a super nice little car. Very reliable, zero maintenance costs, easy to take care of.
Re: Cheap dependable commuter car. [Re: not_a_charger] #3008357
01/23/22 10:04 PM
01/23/22 10:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
An ex employee had good luck with the cruzes, Drove the cr-p out of them both. The 1st one had abou 120K on it, picked it up for 1800. ran it up to 170K and it was totaled. 2nd one 144K paid about 2200 for it, ran it up to 190k just normal maitenance tyep stuff. the first one did get a new A/C compressor otherwise brakes, tires oil changes. they were both manuals
beer
Re: Cheap dependable commuter car. [Re: TJP] #3008367
01/23/22 10:23 PM
01/23/22 10:23 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I have a 2012 Cruze 2LT Manual I bought new. It had some teething issues but its been basically flawless the last couple years. If its a manual make sure it doesn't whine in 5th or 6th gear and it'll be fine.
The 1.4 engine is super easy to work on but you will need an e-torx plus socket set. I would guess at some point they will all need a valve cover, intake manifold, and vent tube with check valve. All cheap and easy to replace parts.
Compared to a civic or a corolla, its a much more comfortable car and it has a huge trunk. Its a likeable car.
I would say avoid VWs and Nissans. If the Nissan is stick shift and dirt cheap it might be OK.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Cheap dependable commuter car. [Re: goldduster318] #3008372
01/23/22 10:38 PM
01/23/22 10:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My daughter has a '14 Cruze. Bought it w/20k...currently a tick over 100k. It's been a good little car. Couple issues w/t-stat housing leaks(crap design GM!) but other than that...brakes,tires, oil changes.
Re: Cheap dependable commuter car. [Re: Dcuda69] #3008422
01/24/22 07:02 AM
01/24/22 07:02 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
If they are considering buying a timing belt vehicle count on having to do a timing component job. People do not have this done because the car is running fine. Even when the add says its been done chances are it was just the $35 rubber belt replaced and not the idler, water pump, tensioners and seals that are hard and leaking by now.
Keep old mopars alive.
Re: Cheap dependable commuter car. [Re: 2boltmain] #3008435
01/24/22 09:07 AM
01/24/22 09:07 AM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
Honda... we have had several of them..great cars!! in the last 10 years I had a 2011 Civic I bought for commuting then the 2016 Honda HRV I bought after the Civic because I wanted All Wheel Drive. When I was working several of my co workers drove Civics with well over 100,000 miles with minimal problems
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Cheap dependable commuter car. [Re: 11secdart] #3008486
01/24/22 01:07 PM
01/24/22 01:07 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
My wife likes her 2008 Civic Coupe. She has had it since 2007 I do not think many are as clean. There is one in the next block that would scare me! Was driven by a young man who drove it like I drove my Challenger 340 in 1980. He beat on that car like a rented mule! He should have been able to kill it but is now handed down to his younger sister. How it is still running I have no idea but is and is driven all over.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Cheap dependable commuter car. [Re: 340SIX] #3008506
01/24/22 01:42 PM
01/24/22 01:42 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Anything with the Toyota 1.8 in it. Pontiac Vibe leads people to believe that you support GM (LOL). 292K on mine.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Cheap dependable commuter car. [Re: oldjonny] #3008509
01/24/22 01:45 PM
01/24/22 01:45 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
having sorted out an 07 Civic for a friend this past summer I can state that Honda's are NOT easy to work on.
Being a hybrid didn't help either. AC compressor was one of the issues.
Re: Cheap dependable commuter car. [Re: Sniper] #3008541
01/24/22 02:54 PM
01/24/22 02:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have 303,000 on my '96 Breeze, and it's been as bulletproof as can be.
2.0L stick car, mid-30s MPG.
Been a nice commuter, even in big snowfall with winter tires.
More solid than the Japanese stuff of the same era.
I would think the later generation Stratus/Cirrus would be just as good.
That may be too old for the OP's buddy, though.
Re: Cheap dependable commuter car. [Re: 340SIX] #3008543
01/24/22 03:04 PM
01/24/22 03:04 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I believe no one has asked thus far. What is the price range?
Re: Cheap dependable commuter car. [Re: 2boltmain] #3008553
01/24/22 03:32 PM
01/24/22 03:32 PM
340SIX Offline
340SIX  Offline
Come on.
He's Mopar guy and member of Moparts.com he is cheap.
So low price should be assumed.
Re: Cheap dependable commuter car. [Re: 340SIX] #3008566
01/24/22 04:34 PM
01/24/22 04:34 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Ford Fusion is the most dependable bang for the buck and cheaper than most other econo boxes to insure!
KID
Re: Cheap dependable commuter car. [Re: Kidsixpack] #3008592
01/24/22 06:34 PM
01/24/22 06:34 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree Civic maybe not a hybrid though. Older ones won't be anyway. Corolla too. And as Not a Charger mentioned Ford Focus were good but not pre-'03 (I believe) because they had a lot of issues.
Facts are stubborn things.
Re: Cheap dependable commuter car. [Re: larrymopar360] #3008594
01/24/22 06:39 PM
01/24/22 06:39 PM
nowhere
nowhere
You realize that an 07 Civic hybrid, which is what I was referring to, is 15 years old. Most would call that an old car.
Re: Cheap dependable commuter car. [Re: Sniper] #3008599
01/24/22 06:46 PM
01/24/22 06:46 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Yeah I hear ya. But weren't a lot of that year and even later models not hybrids?
Re: Cheap dependable commuter car. [Re: larrymopar360] #3008603
01/24/22 06:57 PM
01/24/22 06:57 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I had a Toyota Yaris that I drove as a commuter car for almost 300,000 IIRC. Got awesome gas mileage and very dependable. Hardly spent a dime on it.
