Re: Cheap dependable commuter car.
[Re: 1970GTX]
#3008341
01/23/22 09:42 PM
01/23/22 09:42 PM
Posts: 19,912 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Everyone I've spoken to that had a Dart liked it. If you can find an unthrashed Focus or Cruze, you can probably get it cheaper than a comparable Civic or Corolla. My younger daughter just turned 14, and the cars I mentioned are the ones I will be looking to get for her. Market has changed, but 2.5 years ago, I picked up an 06 Civic with 96k on it for my older daughter. Car has been flawless, has 124k on it now. I've done brakes, tires, belts, hoses, fluids, and rear stabilizer links and bushings. I've got about $5k in it, including purchase price.
Avoid anything European. My $.02.
Earning every penny of that moderator paycheck.
DBAP
[Re: 1970GTX]
#3008342
01/23/22 09:44 PM
01/23/22 09:44 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
My coworker is looking for a cheap dependable commuter car.
He needs something that is easy to work on, 4 cylinder, fwd, cheap to repair. The Honda Civic looks like a good candidate.
Anyone have any other suggestions/experience?
Anything to stay away from? My little brother really likes his Honda Insight, 52 MPG?. He's a recent convert from Nissan. Don't know anything about repair costs, he hasn't had any.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: TJP]
#3008367
01/23/22 10:23 PM
01/23/22 10:23 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have a 2012 Cruze 2LT Manual I bought new. It had some teething issues but its been basically flawless the last couple years. If its a manual make sure it doesn't whine in 5th or 6th gear and it'll be fine.
The 1.4 engine is super easy to work on but you will need an e-torx plus socket set. I would guess at some point they will all need a valve cover, intake manifold, and vent tube with check valve. All cheap and easy to replace parts.
Compared to a civic or a corolla, its a much more comfortable car and it has a huge trunk. Its a likeable car.
I would say avoid VWs and Nissans. If the Nissan is stick shift and dirt cheap it might be OK.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Dcuda69]
#3008422
01/24/22 07:02 AM
01/24/22 07:02 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
If they are considering buying a timing belt vehicle count on having to do a timing component job. People do not have this done because the car is running fine. Even when the add says its been done chances are it was just the $35 rubber belt replaced and not the idler, water pump, tensioners and seals that are hard and leaking by now.
Keep old mopars alive.
[Re: 2boltmain]
#3008435
01/24/22 09:07 AM
01/24/22 09:07 AM
Posts: 4,980 new jersey usa
11secdart
new jersey usa
Honda... we have had several of them..great cars!! in the last 10 years I had a 2011 Civic I bought for commuting then the 2016 Honda HRV I bought after the Civic because I wanted All Wheel Drive. When I was working several of my co workers drove Civics with well over 100,000 miles with minimal problems
[Re: 340SIX]
#3008506
01/24/22 01:42 PM
01/24/22 01:42 PM
Posts: 5,455 Michigan
oldjonny
Don't argue with me.
Anything with the Toyota 1.8 in it. Pontiac Vibe leads people to believe that you support GM (LOL). 292K on mine.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: 2boltmain]
#3008553
01/24/22 03:32 PM
01/24/22 03:32 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I believe no one has asked thus far. What is the price range? Come on. He's Mopar guy and member of Moparts.com he is cheap. So low price should be assumed.
[Re: Kidsixpack]
#3008592
01/24/22 06:34 PM
01/24/22 06:34 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I agree Civic maybe not a hybrid though. Older ones won't be anyway. Corolla too. And as Not a Charger mentioned Ford Focus were good but not pre-'03 (I believe) because they had a lot of issues.
Facts are stubborn things.
[Re: larrymopar360]
#3008594
01/24/22 06:39 PM
01/24/22 06:39 PM
Posts: 6,253 nowhere
Sniper
nowhere
I agree Civic maybe not a hybrid though. Older ones won't be anyway. You realize that an 07 Civic hybrid, which is what I was referring to, is 15 years old. Most would call that an old car.
[Re: Sniper]
#3008599
01/24/22 06:46 PM
01/24/22 06:46 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I agree Civic maybe not a hybrid though. Older ones won't be anyway. You realize that an 07 Civic hybrid, which is what I was referring to, is 15 years old. Most would call that an old car. Yeah I hear ya. But weren't a lot of that year and even later models not hybrids?
