82-225 /6 flywheel? #3006719
01/19/22 09:51 AM
01/19/22 09:51 AM
scratchnfotraction Offline OP
thought I would confirm it is /6 specific before I toss it in the scrap pile.
130 tooth/ 10.5 clutch
wondering if it will work on a 318 to save some $ it looks to be neutral balance?
if it is /6 specific then the search for a 318 130 tooth/10.5 clutch & bell housing continues.
TIA
Re: 82-225 /6 flywheel? [Re: scratchnfotraction] #3006796
01/19/22 01:56 PM
01/19/22 01:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 6-bolt 130-tooth flywheel fits all V8's (except the Hemi) and sixes from '62 into the early 2000's. Only difference is internal/external balance.
Re: 82-225 /6 flywheel? [Re: John_Kunkel] #3006879
01/19/22 05:31 PM
01/19/22 05:31 PM
Thanks John!
sounds like I can use it and save some cash. as of fact that save enough to get the gasket/seal kit & the 833 rebuild book I need. most bells I am see online (at reasonable pricing) are for the 130 tooth flywheel/10.5 clutch & are for A-body so the next hurdle is the input bearing retainer sizing. I will measure my 833od retainer tonight to get started.
do you change the bearing size to go with the smaller retainer?
Re: 82-225 /6 flywheel? [Re: scratchnfotraction] #3007176
01/20/22 01:26 PM
01/20/22 01:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the retainer bolt pattern; some retainers will work with both bolt patterns, some not.
Re: 82-225 /6 flywheel? [Re: John_Kunkel] #3008759
01/25/22 10:49 AM
01/25/22 10:49 AM
I see my 435 has a large retainer with a smaller 4xx" bolt pattern and my 833od has the large retainer 5+" bolt pattern so they do not swap for sure.
so far about the same price on the Lakewood cast alum bell for SB & BB 833/833od/tremac 5 speed are 400$ -/+ and a mopar A or B-body SB 833 bell goes about 400$
thinking I will go for the bell I found for a 72-body SB 833 bell about 200$ and have the retainer hole opened up for the 833od retainer or just get a rebuilt B-body 833 trans to fit the 72 bell with out modifrying it.
