1968 Charger pass #3002954
01/07/22 06:04 PM
01/07/22 06:04 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
well I finally made it to the track, SAME FRIGIN fuel pressure problem as before GERRRRRRR, BUT I pulled 3 wheelies LOL, MPH was down at least 4mph because of fuel pump problems, still ran a best of 10.93,,,,,,,,1.51 60 ft, also got to race a new Super Stock Challenger, he kicked my a$$
Re: 1968 Charger pass [Re: CSK] #3002955
01/07/22 06:07 PM
01/07/22 06:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice going Charlie!!
First 10 in that thing?
What does the fuel pressure drop to?
Re: 1968 Charger pass [Re: fast68plymouth] #3002960
01/07/22 06:14 PM
01/07/22 06:14 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
I cant duplicate it on the street, will post video & you can hear it, on the data log it spikes very fast through out the run from 20 psi back up to 50, in a 1 second veiw in the log it does it about 4 times Yes 1st 10 smile ,, and I remembered to shift LMAO
Re: 1968 Charger pass [Re: CSK] #3002961
01/07/22 06:15 PM
01/07/22 06:15 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Re: 1968 Charger pass [Re: CSK] #3002970
01/07/22 06:46 PM
01/07/22 06:46 PM
So. Burlington, Vt.
So. Burlington, Vt.
You can def hear it cutting out on the top end.
Re: 1968 Charger pass [Re: CSK] #3002975
01/07/22 07:05 PM
01/07/22 07:05 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Congrats again. Car looks crazy cool now with the wing on it.
Was most of the improvement from 60 foot, or where did you pick up the most?
Rich H.
Esse Quam Videri
Re: 1968 Charger pass [Re: ZIPPY] #3002981
01/07/22 07:27 PM
01/07/22 07:27 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Thank you !!! , its hard to say, with the fuel pump issue , but I did leave at 3200 rpm foot brake this time, usually off idle or about 2k
Re: 1968 Charger pass [Re: CSK] #3003009
01/07/22 08:36 PM
01/07/22 08:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Great news on the 10! It looks cool with the injection stacks.
Can you log voltage to the pump? That might help narrow it down.
Re: 1968 Charger pass [Re: Jeremiah] #3003028
01/07/22 09:46 PM
01/07/22 09:46 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
I will do that 1st, BUT I rewired it after the last time with a HD relay now in the trunk, its just hard to test on the streets now that my Used to be small town has exploded & is now basically Houston. traffic is REALY bad now.
Re: 1968 Charger pass [Re: CSK] #3003082
01/08/22 07:03 AM
01/08/22 07:03 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Congrats on the new best! That is always a good feeling, especially when breaking a barrier like 11.00.
What is your fuel tank vent setup like? I wonder if you have a problem there under max demand(like high gear on a dragstrip lol). Just a though!
68 Barracuda Formula S 340
Re: 1968 Charger pass [Re: Bad340fish] #3003146
01/08/22 12:40 PM
01/08/22 12:40 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
I had thought that from before & put a 3/8 vent tube, thanks for the suggestion
Re: 1968 Charger pass [Re: CSK] #3003159
01/08/22 01:44 PM
01/08/22 01:44 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Congrats! There's more in it for sure because to me it's laying down more than just near the end based on sound. Again congrats!
Re: 1968 Charger pass [Re: HardcoreB] #3003207
01/08/22 03:52 PM
01/08/22 03:52 PM
moparx Offline
moparx  Offline
way to go ! up boogie bow
as others have said, there is more in it for sure, after you get the fuel issue sorted.
and the wheelie pic is FANTASTIC ! punkrocka
beer
Re: 1968 Charger pass [Re: CSK] #3003403
01/09/22 11:38 AM
01/09/22 11:38 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I love the launch pic! Car definitely not happy on the back half, though.
How fast was the Super Stock Challenger?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 1968 Charger pass [Re: Brad_Haak] #3003445
01/09/22 01:37 PM
01/09/22 01:37 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Thanks guys for the positive responses, even with all the problems I have had with this car this day made me VERY happy & felt it has all been worth it, did I tell Y'all I remembered to shift LOL !!!! smile That pass was a 10.20ish, 1st time out for it, later ran 10.teens, with worse air. it pulled the wheels also
Re: 1968 Charger pass [Re: CSK] #3008453
01/24/22 10:58 AM
01/24/22 10:58 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
I was sent another picture, Had to share with Y'all, it made all the work on my street car worth it, puts a big ole smile on my face even though I still have the fuel pump issue
Re: 1968 Charger pass [Re: CSK] #3008455
01/24/22 11:07 AM
01/24/22 11:07 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Looks like that engine is hard against the retaining strap!!LOL
Joe
Re: 1968 Charger pass [Re: CSK] #3008463
01/24/22 11:38 AM
01/24/22 11:38 AM
So. Burlington, Vt.
So. Burlington, Vt.
Awesome pic!! up
Is the point where the engine starts to have the misfire issue the highest rpm on track to that point?
And what is the rpm where it starts acting up?
I’m just wondering if it’s possibly a valvetrain issue, and the fluctuating fuel pressure is just a by product of the EFI chasing the fuel curve around after the valvetrain gets unhappy.
What I think/recall you had for springs and RR seemed to me like it might be on the edge for high rpm control considering the weight of the lifters.
To test it, you would see if you could duplicate the misfire in 2nd gear, and if it does....... see if shifting into 3rd made the misfire go away.
Just spitballing....... since the fuel system work has to this point been unsuccessful.
Re: 1968 Charger pass [Re: CSK] #3008466
01/24/22 11:49 AM
01/24/22 11:49 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Awesome picture, Charlie.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 1968 Charger pass [Re: fast68plymouth] #3008474
01/24/22 12:37 PM
01/24/22 12:37 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Awesome pic!! up
It might have a spring issue also, BUT on the data log the fuel pressure problem starts right away, I can feel it laying down & then pick back up through the intire run, it starts banging in high gear at about 5500 rpm, but it will pull 6300 rpm in 1st & second without banging BUT I can feel it surging as the pressure comes & goes in 1st & second , that said I do think my springs are going away like you said.
