Valve Spring shims : Are they Ok to use? #3001783
01/03/22 10:27 PM
01/03/22 10:27 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I have hardened valve spring shims that I would like to use on stock 340 heads and springs. I know to put them on the Head side, not the retainer side. My question is, has anyone ever had these shims get pounded out over time, buy the spring? Thanks.
Re: Valve Spring shims : Are they Ok to use? [Re: ragtop] #3001789
01/03/22 10:40 PM
01/03/22 10:40 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Every shim I buy for every head is a hardened shim. I refuse to use the cheapies. Any shim will wear over time but the hardened ones hold up well
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Valve Spring shims : Are they Ok to use? [Re: pittsburghracer] #3002137
01/04/22 09:48 PM
01/04/22 09:48 PM
iagree up
i have used standard shims mixed with the tool steel shims and I make sure the harden tool steel, spring steel shims, are installed next to the springs up scope
Re: Valve Spring shims : Are they Ok to use? [Re: ragtop] #3002189
01/05/22 12:25 AM
01/05/22 12:25 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
the main issue it that the shim fits snuggly on the valve guide boss, so they don't slide around. I have never seen one fail if it fits the guide boss correctly. I use common spring shims made for engines that have one side with ridges, that helps them from rotating on the spring pad. Available at any source for engine parts. I buy a lot from Goodson tools.
Re: Valve Spring shims : Are they Ok to use? [Re: jwb123] #3002272
01/05/22 01:18 PM
01/05/22 01:18 PM
Locomotion Offline
Locomotion  Offline
Depending on what you have and trying to accomplish, in some cases you can make adjustments to spring installed height & pressures using +.050" or -.050" locks and/or retainers.
