leaking sand hole in block #299998
04/26/09 12:20 PM
04/26/09 12:20 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
I have been chasing an oil leak in my Hemi and found it to be what looks like a sand hole defect in the block about 1" above the pan rail. It is a very small imperfection about 1/4" long. It is not a crack. More like a small recess.
I have never run into anything like this before. I am hoping something like JB weld will seal it up rather than brazing it.
Has anyone run into something like this and how did you fix it?
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Post deleted by Defbob [Re: 70shaker] #299999
04/26/09 12:46 PM
04/26/09 12:46 PM
Re: leaking sand hole in block #300000
04/26/09 12:54 PM
04/26/09 12:54 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
JB or drill and tap it for a pipe fitting
that Fred is a smart fellow..
Re: leaking sand hole in block [Re: mcat4321] #300001
04/26/09 01:03 PM
04/26/09 01:03 PM
JB WELD forever!!! A neat trick with JB is that you can take a little paint thinner on your finger a SMOOTH it out before it hardens ( great tip for those push rod places on a head ) or on the side of a block you can "smooth" it out with a little thinner then press some like 80 or 30 something grit sand paper on it for that just cast look--
I agree with Fred--smear without fear!
Re: leaking sand hole in block [Re: ] #300002
04/27/09 10:14 AM
04/27/09 10:14 AM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
Thanks guys
Ex Hemi Racer
Re: leaking sand hole in block [Re: 70shaker] #300003
04/27/09 11:18 AM
04/27/09 11:18 AM
I would pull the oil pan off and seal it on the inside also Clean it very thoroughly with brake cleaner or laquer thinner to get rid of the oil residue and then heat it up with a heat gun or haoir dryer until it is hot enough to dry any and all oil reisidue, hotter than you can touch in other words. Let it cool and patch away
