Re: 68 Charger AC heater box
[Re: THESHAKERPROJECT]
#2998477
12/25/21 09:37 PM
12/25/21 09:37 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
[ How do you remove the flanges on the ends of the 2 drain tubes to remove the ac evaporator and drip tray from the heater box . They seem to be crimped on there tight and will not pry off . do you use heat to remove them ?? Thanks in advance for any help . spray them with some penetrating spray & try turning them a little at a time
[Re: 71TA]
#2998709
12/26/21 09:21 PM
12/26/21 09:21 PM
Posts: 10,736 North Dakota
6PakBee
North Dakota
I'm unfamiliar with this topic. Anyone got any pics of what is being discussed?
[Re: 6PakBee]
#2998727
12/26/21 10:40 PM
12/26/21 10:40 PM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
I'm unfamiliar with this topic. Anyone got any pics of what is being discussed? I can get a picture tomorrow of the area talked about
