Re: aluminum heads
[Re: volaredon]
#2998405
12/25/21 03:51 PM
12/25/21 03:51 PM
Posts: 31,042 Oregon
AndyF
can I tack something on here? I have a couple of Magnum 360s here sitting on the floor (mag 318s too, those are in pieces) and I have 1 known good original head and 2 "maybe's" that haven't yet been thru the machine shop. Many guys here want straight line acceleration performance, but I am looking at a different purpose... hauling and towing. Would aluminum heads be an a advantage here? or would I be better with cleaned up, ported iron heads? Talk to Brian at IMM. He'll probably steer you towards some new iron heads.
Re: aluminum heads
[Re: ohiodemon]
#2998553
12/26/21 09:36 AM
12/26/21 09:36 AM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you are going to run a smallish cam (.550 or under) you won’t really notice a difference in TrickFlow, Edelbrock, speedmaster type of heads.
