727 TF Rear Mount on E-Body issue #299455
04/25/09 10:08 PM
04/25/09 10:08 PM
South Western Michigan
gkellycuda Offline OP
Hi!
I recently replaced the rear rubber mount on my 727 TF and it appears it has slipped back out of the bracket. It's supposed to press into the bracket but the aftermarket mount is way to loose. Do they make urethane mounts and a new bracket? The bracket is sheet metal formed in a u-shape and holds the rubber mount. The current doesn't hold the tranny in the right spot to have the right drive shaft angle to the pinion. It appears to be cocked to the right when looking from the tranny toward the rear end. From the side of the car it looks like the drive shaft is lower than the rear pinion right out of the tail shaft of the tranny! I've had a serious vibration for some time and I think this stinken rear mount is the issue. I've put new u-joint in the drive shaft and had it balanced so I'm quite confident it's not that. Any help is appreciated.
1999 Dodge 3/4ton Cummins 24 Valve, 4x4
Re: 727 TF Rear Mount on E-Body issue [Re: gkellycuda] #299456
04/25/09 10:30 PM
04/25/09 10:30 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Hi!
Can you post a picture of the mount ? I think Brewers sell the urethane mounts.
Re: 727 TF Rear Mount on E-Body issue [Re: gkellycuda] #299457
04/26/09 05:24 PM
04/26/09 05:24 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The steel sleeve should have a couple of welds on each side holding it in the U-shaped bracket, not very big weld beads so as to prevent burning the rubber bushing.
Even if the rubber is replaced with poly bushings, the sleeve needs to be welded to the bracket.
Re: 727 TF Rear Mount on E-Body issue [Re: John_Kunkel] #299458
04/26/09 09:47 PM
04/26/09 09:47 PM
Thanks!! That's what I was thinking of doing, but wanted to hear it from someone else. The original was pressed in.
How about the angle of the drive shaft to the rear pinion? I took a few measurements tonight and "trigged" it out. The angle from the tail shaft to the pinion looking from the tail shaft to the rear end equals 3.8 degrees to the right. Isn't is supposed to be in-line with no angle?
Again thanks for the help!
Re: 727 TF Rear Mount on E-Body issue [Re: krw71ragtop] #299459
04/26/09 09:48 PM
04/26/09 09:48 PM
Hi!
Do you have a website or phone number for Brewers?
Thanks!
Re: 727 TF Rear Mount on E-Body issue [Re: John_Kunkel] #299460
04/26/09 09:54 PM
04/26/09 09:54 PM
Also.... Do you have any pics of your 97' Viper GTS? That's one of my favorite mopars. I've wanted one for some time. If you don't want to post it, that's fine, but could you send it via PM?
Thanks again for the info on the rear mount!
Re: 727 TF Rear Mount on E-Body issue [Re: gkellycuda] #299461
04/26/09 10:09 PM
04/26/09 10:09 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Hi!
Thanks!
www.brewersperformance.com 937-698-4259
Re: 727 TF Rear Mount on E-Body issue [Re: krw71ragtop] #299462
04/26/09 10:10 PM
04/26/09 10:10 PM
Thanks!!!
Re: 727 TF Rear Mount on E-Body issue [Re: gkellycuda] #299463
04/27/09 07:50 PM
04/27/09 07:50 PM
Rio Linda, CA
Rio Linda, CA
Here's a pic of my Viper, not much different than any other '97.
Re: 727 TF Rear Mount on E-Body issue [Re: John_Kunkel] #299464
04/30/09 12:44 PM
04/30/09 12:44 PM
Sweet! Any mods?
