Need opinions............
#299293
04/25/09 08:24 PM
04/25/09 08:24 PM
Posts: 45 Cincinnati,Ohio
paulgrr63
Cincinnati,Ohio
First off let me say HI! I am new to these forums. I usually hang around on dodgecharger.com.I have an issue with my charger and I'm about to give up. My Charger turns off then back on every time I accelerate. Sometimes when it does it when I'm turning but runs fine when its wide open. I replaced the gas tank, pickup, fuel filter(3 times), fuel pump and carb. The first time I replaced the fuel filter it ran like a beauty for about 5 minutes then it shut down. I'm out of ideas. Need help. Thanks.
Re: Need opinions............
[Re: paulgrr63]
#299296
04/25/09 08:54 PM
04/25/09 08:54 PM
Posts: 78 Colorado
PlumCrazyFury
Colorado
Hi,
Welcome to moparts. Is it shutting down like it is losing fuel like a sputter and a stop or does it just shut clean off instantly? Do you have an electric or mechanical fuel pump?
Big Block to the Rescue!
[Re: StandOnIt]
#299299
04/26/09 08:42 AM
04/26/09 08:42 AM
it seems that he is having the same problem with his car as i am having with the 2bbl i have on my fifth avenue. thought it was the accelerator pump but mine is still fine. still stumped. checked timing, fuel pressure, vaccum... if you find anything out let me know. mine does this and if im at a red light it stalls unless i go very gently on the throttle. with mine there is no stuttering just shuts off.
[Re: paulgrr63]
#299300
04/26/09 08:46 AM
04/26/09 08:46 AM
RapidRobert
yes more details esp on the carb & WHEN it does it(load no load/what rpm & what exactly "it" is(a sputter or is it a instant dying) & how long has it been doing it & what ign etc on the car & what recent changes other than those mentioned
[Re: RapidRobert]
#299302
04/26/09 01:17 PM
04/26/09 01:17 PM
paulgrr63
Cincinnati,Ohio
The car is %100 original. All engine components are the same with the exception of the water pump and AC compressor. The carb was rebuilt. It is a sputter but if I keep my foot down on the gas it will die. If I let up it picks up again.
[Re: paulgrr63]
#299303
04/26/09 06:09 PM
04/26/09 06:09 PM
is that a 2bbl or a 4bbl carb.
