Page 3 of 3 1 2 3
Re: lost cam lobe on break in twice [Re: Von] #299249
04/26/09 10:23 PM
04/26/09 10:23 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I was able to find the lifter from the wasted lobe and looked more closely at it. It looks like the scarring is all in one direction- like it never rotated.
I will change to another brand with a lift no more than .500 and clean up my lifter bores. No cam lube on the sides!
So have you pulled the motor down after losing 2 cams?
OR ...at least drop the engine oil pan. THEN put a magnet in there to collect the rest of the "trash".
Re: lost cam lobe on break in twice [Re: dOrk !] #299250
04/26/09 10:44 PM
04/26/09 10:44 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
A bunch of the metal is up in the skirts by now...
Re: lost cam lobe on break in twice [Re: Robbins] #299251
04/27/09 11:36 AM
04/27/09 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How much lifter rotation is there in say spinning the motor over one revolution?
I mean say you mark the lifter and the bore....and you turn the motor over one revolution....how far should the lifter turn from the mark on the block?
not much , but the lifter should rotate close to a 1/4 turn , it doesn't rotate till it goes over the nose of the lifter lobe . I usually mark all lifters and all pushrods and rotate the crank untill I have seen 1 full revoution of all the lifters and pushrods .
Re: lost cam lobe on break in twice [Re: 64Post] #299252
04/27/09 11:37 AM
04/27/09 11:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Never mind how trashed the oil pump is .
Page 3 of 3 1 2 3
