ok might be splitting hairs on my 8.75 but............ #299136
04/25/09 06:26 PM
04/25/09 06:26 PM
Georgia
moparjimbo60 Offline OP
Georgia
rebuilding my 8.75 after breaking bearing caps, went with 742 case billet caps, bolts thru housing to preload caps, now is there any gains in welding the inside of housing where the bubble part (for lack of a better word)where it meets the main part of the housing just curios i know someone out there has tried this before. any takers ?
Post deleted by Defbob [Re: moparjimbo60] #299137
04/25/09 06:36 PM
04/25/09 06:36 PM
Re: ok might be splitting hairs on my 8.75 but............ #299138
04/25/09 06:49 PM
04/25/09 06:49 PM
Georgia
Georgia
seems to make sense there is almost an inch from where its welded outside to the flange on the inside . think i will try it
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299139
04/25/09 08:43 PM
04/25/09 08:43 PM
Georgia
Georgia
ok so you guys saying that no one has thought this through. there are some super heroes on this site give me your imput. if there is nothing to gain i wont fool with it just seems good
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299140
04/25/09 08:52 PM
04/25/09 08:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
nothing to think about. no matter what you do to it, it's still prone to break
Re: ok might be splitting hairs on my 8.75 but............ [Re: Quicktree] #299141
04/25/09 08:59 PM
04/25/09 08:59 PM
Georgia
Georgia
i understand that the 8.75 is not the best rear axle outthere. i cant spend what it takes to go dana or 9 inch. have done the math not in my racing budget, just need to do all i can to make the thing live.
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299142
04/25/09 08:59 PM
04/25/09 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would be better to put a back brace on it, it
would be able to hold more load(better leverage).
Some people here just dont like the 8 3/4 but its
been doing great in my car (with a 1.19 60' but my
car is light)
Re: ok might be splitting hairs on my 8.75 but............ [Re: MR_P_BODY] #299143
04/25/09 09:00 PM
04/25/09 09:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
car is light)
I knew that would wake you up
Re: ok might be splitting hairs on my 8.75 but............ [Re: MR_P_BODY] #299144
04/25/09 09:04 PM
04/25/09 09:04 PM
Georgia
Georgia
still thinking about the brace the thing is only 36 inches flange to flange would it still help ?
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299145
04/25/09 09:07 PM
04/25/09 09:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes, thats not much different than mine, you should
have put it on when you shortened it, they are a must
if you 60' at all
Re: ok might be splitting hairs on my 8.75 but............ [Re: MR_P_BODY] #299146
04/25/09 09:10 PM
04/25/09 09:10 PM
Georgia
Georgia
thanks mr p i will order 1 monday i bought the car with it narrowed , i think im going with new drive shaft with 1350 joint also. thanks for all your help maks making a decision alot easier
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299147
04/25/09 09:19 PM
04/25/09 09:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I prefer to make them 2" X 3" or better is 2" X 4"
and cut it yourself. Just square the tube on the back
of the diff and use a set of dividers to scribe it
for the contour, I run it right out to the flange
EDIT
Make sure it clears your shocks
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299148
04/25/09 09:19 PM
04/25/09 09:19 PM
Canada
CrAzYMoPaRGuY Online content
CrAzYMoPaRGuY  Online Content
Canada
I went with a heavy gauge backbrace and my load bolt threaded tubes are welded to the outer brace and inner pumpkin. My rear is fairly narrow.
CrAzYMoPaRGuY
Re: ok might be splitting hairs on my 8.75 but............ [Re: MR_P_BODY] #299149
04/25/09 09:23 PM
04/25/09 09:23 PM
Georgia
Georgia
im on that havnt thought to build one dont sound to hard i get at it thanks for your help
Re: ok might be splitting hairs on my 8.75 but............ [Re: CrAzYMoPaRGuY] #299150
04/25/09 09:25 PM
04/25/09 09:25 PM
Georgia
Georgia
thats awesome thanks for the picture that helps alot
Re: ok might be splitting hairs on my 8.75 but............ [Re: MR_P_BODY] #299151
04/25/09 09:28 PM
04/25/09 09:28 PM
Georgia
Georgia
is it ok for the bolts true the housing to be on the boltfor the adjuster lock or should it be beside it ?
Re: ok might be splitting hairs on my 8.75 but............ [Re: moparjimbo60] #299152
04/25/09 09:46 PM
04/25/09 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put the load bolts in so that they just press on the
center of the caps.... if you have seen a stock cap
break you will see that they break near the center of
the cap. I like to weld a heavy wall tube to the back
of the housing then weld it to the back brace, that
way you dont get oil in the back brace... then weld
a nut on the back brace so its holding the load.
Look at Crazy's pic and you can see how its all done
EDIT
if it presses on the bolt... no big deal it JUST
pressing on it, I just snug it on the bolt/cap
then tighten the lock nut
