Re: switching from 8 3/4 to dana
[Re: gregcharger72]
#2988697
11/24/21 04:37 PM
11/24/21 04:37 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
would the driveshaft length remain the same when doing this swap? I've order an s60 unit to replace my 8 3/4 . The driveshaft will need to be shortened
[Re: CSK]
#2988699
11/24/21 04:40 PM
11/24/21 04:40 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
would the driveshaft length remain the same when doing this swap? I've order an s60 unit to replace my 8 3/4 . The driveshaft will need to be shortened Agree , on mine it was about 1.5 " difference if I remember correctly
6.50 @105.26
[Re: CSK]
#2988700
11/24/21 04:41 PM
11/24/21 04:41 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
would the driveshaft length remain the same when doing this swap? I've order an s60 unit to replace my 8 3/4 . The driveshaft will need to be shortened Good time to step up to a 1350 joint in the front.
[Re: CMcAllister]
#2988704
11/24/21 04:50 PM
11/24/21 04:50 PM
Posts: 112 pa
gregcharger72
pa
would the driveshaft length remain the same when doing this swap? I've order an s60 unit to replace my 8 3/4 . The driveshaft will need to be shortened Good time to step up to a 1350 joint in the front. well that's not what I wanted to hear. i have a carbon fiber driveshaft.. man this is getting expensive !!! I have the 1350 conversion on my current set up.
[Re: BloFish]
#2988877
11/25/21 06:01 AM
11/25/21 06:01 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Just move everything forwards a little bit at a time,keeping the prop AS IS lol NEVER GO BACK AND NEVER LOOK BACK...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
