Question about plumbing. #2986957
11/19/21 07:41 PM
11/19/21 07:41 PM
Anderson, SC
resqguy Offline OP
resqguy  Offline OP
Anderson, SC
I'm building a house (owner - builder) and have a question for any plumbers about rules for vents. I have a situation where I need to run a vent horizontally above the floor but below the attic. The code says that horizontal vents have to be at least 6 in. above the flood level rim of the highest fixture served. In my case I am plumbing in a tub. What does the code mean by flood rim? Would that be the tub drain, the overflow, or the rim of the tub itself? I'm limited on how to design the vent and alternative methods would mean cutting floor trusses, or other more illegal solutions.
Re: Question about plumbing. [Re: resqguy] #2987047
11/20/21 01:05 AM
11/20/21 01:05 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Generally they want, 6" above the rim or 42" above the floor, whatever is greater, that way the system can never fill with water no matter what, like if a 36" tall sink is added later. What you can get by with varies but the rim is the top of the tub, not the overflow.
Re: Question about plumbing. [Re: 4406bbl] #2987113
11/20/21 10:37 AM
11/20/21 10:37 AM
Anderson, SC
resqguy Offline OP
resqguy  Offline OP
Anderson, SC
That is what I thought. The tub is a drop in/roman tub and the deck extends into the shower as a bench. There is no floor to ceiling cavity at the front of the tub and the deck tops out about 19in above the floor. I was going to run a 45 degree vent to the outside wall but it won't clear the trusses and the decking. Could I modify the vent, flattening the angle, with a pair of 22 degree fittings? I think that is the best of my options.
Re: Question about plumbing. [Re: resqguy] #2987117
11/20/21 10:48 AM
11/20/21 10:48 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
I gots a quickie Q !
Cost to run a camera down a sewer line about 50 feet.....
THEN run a snake down it to clear out some mild root intrusions?
200 beans ?
Re: Question about plumbing. [Re: dOc …] #2987135
11/20/21 11:30 AM
11/20/21 11:30 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
200 beans ?
Cost me $150 to get a hairball snaked out of my tub drain. I really have to learn to work a snake.
Re: Question about plumbing. [Re: resqguy] #2987173
11/20/21 01:19 PM
11/20/21 01:19 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
[quote=resqguy]I'm building a house (owner - builder) and have a question for any plumbers about rules for vents. I have a situation where I need to run a vent horizontally above the floor but below the attic. The code says that horizontal vents have to be at least 6 in. above the flood level rim of the highest fixture served. In my case I am plumbing in a tub. What does the code mean by flood rim? Would that be the tub drain, the overflow, or the rim of the tub itself? I'm limited on how to design the vent and alternative methods would mean cutting floor trusses, or other more illegal solutions. [/quo
Google Studor Vent
You might be able to use one in your application.
Re: Question about plumbing. [Re: resqguy] #2987176
11/20/21 01:53 PM
11/20/21 01:53 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I don't know how far away your stack is but sometimes with center outlet tubs you just wet vent it below the floor to the stack. 2" can go 8 feet, 3" can go 12 feet.
